ef9 front end(ef squad, if you could help)
Old Jul 8, 2003 | 06:29 PM
LD_EGSICK's Avatar
Default ef9 front end(ef squad, if you could help)
i did a search:
i just got my jdm front from hmo, and i need help with the wiring for the head lights, corner and side markkers. out here in va there an't much jdm lovers or ever even heard much of it, soo i'm a out cast living the ef9 dream.
Old Jul 8, 2003 | 09:09 PM
LD_EGSICK's Avatar
Default Re: ef9 front end(ef squad, if you could help) (mysiqu)
rice is nice but jdm is for ever
Old Jul 8, 2003 | 09:16 PM
andrew dc's Avatar
buy a three pronged socket... to accept an H4 or H4h.. any parts store should have one... since the JDM light acts as both high and low, you will need to splice the current lines. US model has high and low each with a positive (red) and negative (black) you will use both positives on the parallel sides of the bulb... then use on negative for the top of the bulb, to ground it....
Hope that made sense.
Andrew
4thgenx42
13
Mar 4, 2007 09:57 AM
RicharDC4
Sep 13, 2006 12:00 AM
cyrock
Aug 30, 2005 08:53 AM
GoodFella
Oct 3, 2001 02:11 PM
