what to use to wire into the ecu?
Old Jul 8, 2003 | 06:28 PM
Dancing is Forbidden's Avatar
Default what to use to wire into the ecu?
I need to wire in the wires for a 4 wire O2 sensor and knock sensor and just need to know how to get it into the ecu itself. thanks
1992 CX hatch-->b16a w/p61 ecu
Old Jul 8, 2003 | 06:29 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: what to use to wire into the ecu? (EF9_SiR)
i have a habbit of cutting any wire harness i am tossing in the trash.
i have a pleathora of extra pins. thats the way to go. you need obd 1 obd2 or obd0? i may be able to hook you up. let me know.
Old Jul 8, 2003 | 06:30 PM
SprayinCX's Avatar
just splice,solder,and wrap them up real good that is what i did hasn't failed me yet
Old Jul 8, 2003 | 06:32 PM
Mr. Badwrench
Default Re: what to use to wire into the ecu? (SprayinCX)
i think he is asking about back pinning. if there isnt a wire already there.
Old Jul 8, 2003 | 06:53 PM
built562's Avatar
Default Re: what to use to wire into the ecu? (boostedcivicsir)
you need some oem pins, get some form a junk yard, dont use anything else besides oem pins. but if you are cutting or splicing you should always use solder and wrap them.
andyvaj
Aug 11, 2007 09:24 AM
FastAsleep
Jun 28, 2007 09:40 AM
quicksol95
Nov 7, 2004 10:26 AM
dingusjt
Nov 13, 2003 10:18 AM
