Fuel system problem in 89 sedan LX
Old Jul 8, 2003 | 05:50 PM
Aquafina's Avatar
Default Fuel system problem in 89 sedan LX
1989 Civic LX sedan MT. Engine will turn but won't start. It's not getting fuel. When air is blown into fuel pipe (that connects to TB deal) some fuel will come out. Checking the fuel pump tomorrow but just wanted to see what anyone on here had to say about it.
Old Jul 8, 2003 | 06:42 PM
blah13's Avatar
Default Re: Fuel system problem in 89 sedan LX (SuperStreetRX7)
Is your main relay clicking? If so is your fuel pump priming?
Old Jul 8, 2003 | 07:13 PM
Aquafina's Avatar
Default Re: Fuel system problem in 89 sedan LX (blah13)
Yes, the main relay is clicking, not sure if the fuel pump is priming, how do I find out?
Old Jul 8, 2003 | 07:34 PM
sleeper4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperStreetRX7 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, the main relay is clicking, not sure if the fuel pump is priming, how do I find out?</TD></TR></TABLE>
if you can hear the main relay clicking, then you should be able to hear the fuel pump priming (whirring noise) for 2 seconds while the CEL is on at start.
pull your backseat and listen closely when you turn the key to start. as soon as the main relay CLICKS, the fuel pump will start priming (assuming the pump is ok).
Old Jul 8, 2003 | 07:35 PM
Aquafina's Avatar
Default Re: Fuel system problem in 89 sedan LX (sleeper4dr)
I'll try it tomorrow before I go to work.
2ndthtsurplace
Apr 10, 2011 11:15 AM
JimmyM86
15
Oct 18, 2007 08:44 PM
whitehf
Aug 6, 2006 01:22 PM
shoebox
Feb 11, 2004 11:18 AM
