Still working on the turbo setup... more questions...
Old Jul 8, 2003 | 05:22 PM
joey1320's Avatar
Default Still working on the turbo setup... more questions...
Okay I got the 450cc injectors installed. The AFC is in place and now I want to know if I can use a spare Civic SI's fuel pump I got in the garage, instead of the factory HF fuel pump I got right now?
Will it be enough fuel to run my turbo setup(10lbs.) or will I need an aftermarket one?
Also if anyone has done this before please post your info.
Old Jul 8, 2003 | 05:45 PM
sporkcrx's Avatar
Default Re: Still working on the turbo setup... more questions... (joey1320)
You can swap it in...but I believe the HF and Si's use the same pump. Also, for the hack the pressure is low enough that you don't need an aftermarket pump (i think, so don't quote me) AND WHERE THE HELL ARE PICS! be sure to post in FI when you get it done, it's part of the rules
Old Jul 8, 2003 | 06:19 PM
joey1320's Avatar
Default Re: Still working on the turbo setup... more questions... (sporkcrx)
I wasn't talking of the CRX SI's fuel pump, it's a '00 SI's fuel pump.Sorry...
Will that one work?
I got the AFC/ijectors in and I decided to set the lo/hi thrttle settings as follow:
1k-4k -40%
4k-5.2k -38%
5.2k-6.4k -36%
6.4k-7.4k -35%
and I decide to start the car after the settings were in... well the car ran smooth, with no issues whatsoever. Is this enough fuel for the turbo or will I need more fuel?
The pics haven't been taken. I only got the ones from the motor build up and the clutch/tranny setup. But they'll come soon.
I'll probably get a manifold made in PR before the summer's over, but fo now only the adapter/hf mani. will do...
peaNUTS6
Honda Civic (2001 - 2005)
Apr 2, 2007 11:30 AM
djnikko
Mar 7, 2004 09:47 AM
RicedREX
Dec 21, 2003 04:27 PM
ImportHatch
Oct 1, 2002 10:37 AM
SpecFIB18
Jul 9, 2001 09:04 AM
