need some input on this all motor crx setup
Old Jul 8, 2003 | 05:03 PM
Optiks.'s Avatar
Default need some input on this all motor crx setup
here is what i want to do eventually
i can get a GSR parts car pretty cheap, obd 1
swap in the b18c, sell off the tranny and the only one i could get is the 90-93 cable tranny since the crx's is a cable- but i dont know which cable da tranny would be good, yet
i would like to run reprogramed gsr ecu with a vafc
header tech header
then in a bit swap in a b20z, just a few qustions, what do you guys do with the little ridge in the combustion chambers of the gsr head ?
so basically it will be
-GSR donor car, sell the tranny for a cable DA one
-Sell off the GSR block or keep it as a spare and get a b20z block
-with reprogrammed ecu and vafc and maybe some cams
and whaever is needed to support the cams
i just dont know if the GSR parts car is worthwhile since the only thing staying is the head from it, but i can sell everything from the interior and rear brakes unless i can convert the crx to hydro, but i kind of like the cable feel better
Old Jul 9, 2003 | 01:49 PM
Optiks.'s Avatar
Default Re: need some input on this all motor crx setup (Optiks)
Old Jul 10, 2003 | 04:58 AM
CHEETAH's Avatar
it'll be cheaper for you to pickup a jdm 1st gen b16a swap and build from there especially if you're gonna use a b20 block eventually ... why do you think you need a gsr parts car ? maybe if you're innovative you can transfer the gsr dash/harness/wiring to the crx ... put in some power windows and locks from the gsr ...
greg
Old Jul 10, 2003 | 01:54 PM
Optiks.'s Avatar
Default Re: need some input on this all motor crx setup (CHEETAH)
i can get a gsr parts car cheaper then a 1st gen b16a
Old Jul 10, 2003 | 02:48 PM
itsallmotor's Avatar
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
then you're going to jail for highway robbery
Old Jul 10, 2003 | 03:03 PM
Optiks.'s Avatar
Default Re: need some input on this all motor crx setup (hondavtecfanatic)
haha, no my dad goes to those auctions that the junkyards buy their cars from, many integras in the $1000 or less price range, but with an irreparible title
HondaBurger
Jun 20, 2007 01:37 PM
GG-SquadDB
Mar 20, 2004 09:26 AM
BrokdwnCrx
Jun 28, 2003 05:03 AM
elmalouno
Jun 7, 2003 09:48 PM
