checklist of parts needed(rear sway bar on 5th gen)
Old Jul 8, 2003 | 01:48 PM
B_CRUZ!'s Avatar
Default checklist of parts needed(rear sway bar on 5th gen)
Well it has come time for me to add a rear sway bar to my car and I need a checklist for the misc parts I need.
So far I have:
gs-r rear sway bar
ITR lca's
I know the GS-R rear sway bar is only 14mm but I haven't driven a car with a rear sway bar in so long that I don't want to jump the gun and add a 23mm one. I want to get used to the gs-r one first.
where can I get the misc bolts and whatever brackets I need?
TIA.
Old Jul 8, 2003 | 02:12 PM
navin's Avatar
Default Re: checklist of parts needed(rear sway bar on 5th gen) (B.CRUZ)
you forgot endlinks..
honestly I'd set it up and go 22 mm ITR + beaks kit... and eh3 civic si front sway 21 mm..
I have friends that just use the ITR bar in the rear, no front and as long as you dont try to do anything stupid you are fine..
If you do, remember the throttle is your friend
Old Jul 8, 2003 | 02:20 PM
rob d's Avatar
You don't need "ITR" LCA's. You can use regular Integra rear LCA's. Or Civic's LCA's that came with a rear anti-sway bar. If you use ITR LCA's you will have to use ITR rear shocks.
Old Jul 8, 2003 | 02:34 PM
navin's Avatar
Default Re: checklist of parts needed(rear sway bar on 5th gen) (rob d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rob d &raquo;</TD></TR><TR><TD CLASS="quote">You don't need "ITR" LCA's. You can use regular Integra rear LCA's. Or Civic's LCA's that came with a rear anti-sway bar. If you use ITR LCA's you will have to use ITR rear shocks. </TD></TR></TABLE>
forgot to say that, what B you got the mad jdm grEEn suspenion now?
Old Jul 8, 2003 | 02:35 PM
B_CRUZ!'s Avatar
Oh sorry forgot to mention I have EG6 Tein HA's which require ITR lca's.
Navin, i really don't want to start out with a 22-23 mm bar in the rear. I had a bad experience when I had my 92 SE-R and a rear sway bar. lets just say I freaked out when I had to avoid something in the rain on the freeway....
once I get used used to the handling characteristics though, I will get a 22mm ITR bar.
so what else do i need to get... I already have a gsr bar and ITR lca's...
Old Jul 8, 2003 | 08:06 PM
nijia555's Avatar
you will need bracket flanges for the swaybar to mount to the subframe. The bushings for these, swaybar bushings, endlinks and bushings for those.
I have the part numbers for the itr swaybar parts, but your numbers will be different.
i have had my bar and stuff for over 5 months now, maybe someday i will actually get this crap on my car.
Old Jul 8, 2003 | 08:53 PM
EX R8ED's Avatar
Default Re: checklist of parts needed(rear sway bar on 5th gen) (nijia555)
2 words....Subframe reinforcement Beaks or BSQ whatever tickles your fancy. You'll need endlinks, unless they came with the bar. If you go on the beaks site or BSQ site there is a checklist sort of thing. Hope this helps.
Old Jul 9, 2003 | 05:35 AM
navin's Avatar
Default Re: checklist of parts needed(rear sway bar on 5th gen) (EX R8ED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX R8ED &raquo;</TD></TR><TR><TD CLASS="quote">2 words....Subframe reinforcement Beaks or BSQ whatever tickles your fancy. You'll need endlinks, unless they came with the bar. If you go on the beaks site or BSQ site there is a checklist sort of thing. Hope this helps.</TD></TR></TABLE>
not for a 14mm rear sway bar
forcefedferio
Jan 22, 2007 10:37 PM
defconsc
Mar 21, 2004 09:37 PM
gabspeed
Mar 17, 2004 04:39 AM
Mr. Softee
Jun 25, 2002 03:01 PM
