Rough idle, running lean, CEL, you name it, need help quick!
Old Jul 7, 2003 | 11:42 PM
SuperRice's Avatar
Default Rough idle, running lean, CEL, you name it, need help quick!
for some reason when I start driving the car when it's still cold the rpms will fall really low and almost stall and pick back up to about 1500rpms. Once the car warms up then it's okay.
However, I have another problem. When the car is warmed up and I step on it, my air/fuel gauge will read rich initially, but once it hits vtec it will slowly drop into the stoich area and eventually go all the way down to lean. If I don't let up on the throttle eventually the CEL will come on.
The weird thing is when the CEL comes on I feel any difference in performance and there is no weird sounds that I can find. Does anyone know what could be wrong?
I've ran a code and it say it's the oxygen sensor, but that can't be b/c my o2 sensor only has 3000km on it.
Please help.
Old Jul 7, 2003 | 11:44 PM
IWearMyKswiss's Avatar
New User
Default Re: Rough idle, running lean, CEL, you name it, need help quick! (SuperRice)
did you tap your A/F ratio gauge into the o2 sensor?
Old Jul 7, 2003 | 11:46 PM
SuperRice's Avatar
no the air/fuel gauge is tapped into the ecu
Old Jul 8, 2003 | 12:17 AM
97hb's Avatar
The idle problem is most likely the IACV getting stuck open or closed.
Old Jul 8, 2003 | 12:19 AM
SuperRice's Avatar
Default Re: Rough idle, running lean, CEL, you name it, need help quick! (97hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97hb &raquo;</TD></TR><TR><TD CLASS="quote">The idle problem is most likely the IACV getting stuck open or closed. </TD></TR></TABLE>
How would I go about fixing this?
Old Jul 8, 2003 | 09:50 AM
SuperRice's Avatar
ttt
Gunnar24
May 17, 2011 08:19 PM
JODYG35950
Jan 14, 2006 06:32 AM
lsvtec92teg
Jan 5, 2005 11:52 PM
speedymon
Nov 28, 2002 08:09 AM
