94-00 acura integra wiring diagram
Old Jul 7, 2003 | 08:34 PM
aira
Guest
Posts: n/a
Default 94-00 acura integra wiring diagram
I was wondering if anyone has any pics or sites with an 94-00 Acura Integra wiring diagram. I'm going to be installing an alarm and this info would be great. Thanks.
Old Jul 8, 2003 | 01:09 AM
philly-O's Avatar
Default Re: 94-00 acura integra wiring diagram (jdm aira)
search, cause i have posted this info as well as many others before.
but here you go...............
12volts
white
ignition harness
Starter black/white + ignition harness
Ignition black/yellow + ignition harness
Power Lock black/white - drivers kick panel
Power Unlock black/red - drivers kick panel
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+ red/black grn plug above fusebox
Parking Lights- green/yellow factory alarm (if equipped)
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger lt. green/red - drivers kick panel
Dome Supervision use door trigger
Trunk/Hatch Pin green -
Hood Pin yellow/red - drivers kick panel
Trunk/Hatch Release blue - at switch
Power Sliding Door
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock
Tachometer blue AC distributor
Horn Trigger gray or blu/grn - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module
MAKE : ACURA | MODEL : INTEGRA | YEAR : 1998
* The logo is registered trade mark of Acura Corporate.
Old Jul 8, 2003 | 06:56 PM
philly-O's Avatar
Default Re: 94-00 acura integra wiring diagram (peichie)
94 civic..
12volts
white
steering column
Starter black/white + steering column
Ignition black/yellow + steering column
Power Lock green/white - 2pin plg blue-taped to
Power Unlock green/red - blue plg behind f-box
Lock Motor none non none
Unlock Motor none non none
Disarm Defeat none non none
Parking Lights+ red/black at fuse box or d.k.p
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger lt. green/red - driver kick panel
Dome Supervision none non none
Trunk/Hatch Pin grn/blk 2 sil.dot - blue conn. above fusbx
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock none non none
Tachometer blue AC 2-pin conn. near dist.
Horn Trigger blu/grn, blu/red - at steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
MAKE : HONDA | MODEL : CIVIC | YEAR : 1994
* The logo is registered trade mark of Honda Corporate.
DA1
Audio / Security / Video
Jan 12, 2006 11:44 PM
importzx
Dec 8, 2004 08:17 PM
InTeGrA B18b1
Dec 30, 2003 03:36 PM
tony
Jul 29, 2003 09:22 PM
E46M3CB
May 12, 2003 11:35 PM
