Anyone sporting an OEM CTR N1 crank pulley?
Old Jul 29, 2001 | 08:22 PM
WayneGro's Avatar
Default Anyone sporting an OEM CTR N1 crank pulley?
I was wondering if this is an upgrade worth doing? Can I expect some desent power gains? Or is our stock ITR pulley's already lightened from the factory? I put AEM pulley's on my delsol Vtec (not crank) and it helped considerably.... I am hoping for the same.
Any experiences or comments to add?
Old Jul 29, 2001 | 08:43 PM
JDM R98's Avatar
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (WayneGro)
I am wondering also will this do good on my R motor?plmk also..thanks
Old Jul 29, 2001 | 08:44 PM
kenji's Avatar
25 Year Member
The USDM ITR crank pulley is lighter and smaller in diameter as compared to the USDM GS-R.
If you are not running AC or PS the CTR N1 pulley is a great idea. The best thing about it is the timing marks are as accurate as the ones on your OEM pulley.
-kenji
[Modified by kenji, 12:11 PM 7/30/2001]
Old Jul 29, 2001 | 10:15 PM
bigTom's Avatar
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (kenji)
does the n1 pulley have the harmonic dampener in it?
Old Jul 30, 2001 | 12:16 AM
JDM_DOHC_SiR's Avatar
New User
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (ek9t)
Nope... Solid....So you would have to make the call on bearing wear
Old Jul 30, 2001 | 02:44 AM
RagingAngel's Avatar
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (JDM_DOHC_SiR)
HOLY MOTHAAAaa.......
13.3 CR on your 18C5??
Do tell..Do tell...
But back on subject...if Honda felt it was ok to release the N1 crank pulley.... on the CTR...I think it's gonna be ok...!
So.....
Old Jul 30, 2001 | 05:12 AM
B18CXr's Avatar
N1 pulley is good, worth the money. Better throttle response.
Old Jul 30, 2001 | 05:26 AM
Dipshit Dan's Avatar
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (B18CXr)
Why bother with the Honda one? Just get a Unorthodox pulley it weighs less than half even with the accessory provisions. THey also make a race one with only the alt belt. Honda's don't have Harmonic balancers and the harmonic dampener does nothing.
Old Jul 30, 2001 | 05:28 AM
Willard's Avatar
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (God)
correct timing marks...
I think there were differences in the two pulleys when Jack installed the Honda one.
Willie
Old Jul 30, 2001 | 05:34 AM
B18CXr's Avatar
For half the price, I would rather have an OEM part with the CORRECT timming marks.
Old Jul 30, 2001 | 07:15 AM
Mike M's Avatar
Founding Member
No and neither does the Stock one
Old Jul 30, 2001 | 10:26 AM
WayneGro's Avatar
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (TypeRmsm)
I have PS, and no AC. Would it still be a worthwhile upgrade? It's only like 130$$
Old Jul 30, 2001 | 07:02 PM
t's Avatar
t
You wont have power steering than.
Old Jul 30, 2001 | 07:46 PM
BUSAFREAK's Avatar
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (t)
I have no AC or PS. Where can I find this pulley???
Old Jul 30, 2001 | 09:02 PM
WayneGro's Avatar
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (ITR1162)
http://www.inlinefour.com
Great service from them.
Old Jul 31, 2001 | 07:41 AM
Yellow Dragon's Avatar
I too have been thinking of getting the N1 CTR crank pulley for my hybrid. I have no A/C or P/S so I think it would be a good upgrade. Hmm... Another mod I didn't know Jack had.
Old Jul 31, 2001 | 09:42 AM
B18CXr's Avatar
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (Yellow Dragon)
I have lots of secrets under the hood..........
[Modified by B18CXr, 1:43 PM 7/31/2001]
Old Jul 31, 2001 | 10:03 AM
Splat's Avatar
Collector-o-Guns and Drinker
Jack - When did your sig change?!?
"Lumpy Toda joy has returned!!"
Old Jul 31, 2001 | 10:14 AM
Willard's Avatar
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (itr009)
hrmness...
Looks like someone placed an order....
Willie
Old Jul 31, 2001 | 10:23 AM
RStoR's Avatar
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (Willard)
that didn't last long!
Old Jul 31, 2001 | 11:00 AM
J.Katman's Avatar
New User
speaking of AC....check out the weight differences in the B-series A/C mount..
Did this lil' comparo test last week...
Old Jul 31, 2001 | 01:57 PM
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (Hallusin8.com)
As for the bearings being ruined, I still believe it was due to something other than the crank pulley. Those pics demonstrate nothing other than the damage incurred. I've been using them for years and under very severe conditions (9200+ RPM, extended high RPM use). Don't you think I'd suffer SOME kind of problem with bearings on ONE of my cars? What about all the other cars I sell them to? NOt one has complained of any kind of bearing wear whatsoever. My GSR had 108,000 miles on it. Bearings were fine. It's a load of BS in my opinion. If you want to be paranoid go ahead. I'm very paranoid but not at the expense of common sense.
Old Jul 31, 2001 | 05:14 PM
BABY NSX's Avatar
This has been the best information I have read on the subject. And I have been looking hard for it..
Thanks a bunch!
Regards,
Old Aug 7, 2001 | 09:03 PM
Suprdave's Avatar
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (BABY NSX)
I saw a video of Christian Rados shop, and they were putting a pulley onto a GSR Motor....It was a Stock Crank Pulley ... Food for Thought...Its not worth 3 Horsepower.
Suprdave
Old Aug 8, 2001 | 04:41 AM
B18CXr's Avatar
Default Re: Anyone sporting an OEM CTR N1 crank pulley? (Suprdave)
HP is not the main goal of a crank pulley, acceleration is where you will feel the difference....light flywheel, same thing Big hp difference?no. but faster car?? yes
gettin it
Jan 27, 2011 04:45 AM
Muckman
Oct 9, 2006 01:56 PM
96 Ls lnTeG
Jan 1, 2004 08:07 AM
2k1 GSR
Feb 15, 2003 04:10 AM
AK94GSR
Feb 10, 2003 06:43 PM
