Spark Plugs for my b16a2, any suggestions????
Old Jul 7, 2003 | 06:42 PM
TwistedSI's Avatar
Default Spark Plugs for my b16a2, any suggestions????
I realize there isn't much of a difference between them all but I've always been one to spend a little more for something that "might" be better. So my question is does anyone have any preferance on plugs? I filled up with 76 the other day instead of Cheveron and I think I fouled one so might as well change them out.
While I've got your attention, what about plug wires? Was thinking of just sticking with good ol Accel since they have always been good to me in other cars.
Old Jul 7, 2003 | 06:51 PM
granada_sun's Avatar
bosch plat 4's....theyre $5/ea. but worth it IMO.
Old Jul 7, 2003 | 07:07 PM
LSVTECoupe's Avatar
i'd just go with how it came from the factory, NGK platinums.. a little expensive but I heard Bosch Plat +4 suck.
Old Jul 7, 2003 | 07:10 PM
Default Re: (LSVTECoupe)
check it out import review did a dyno of bosch plat 4s vs ngk-v-power plats in an all motor d16....
bosch is blue, ngk is red...
bosch plat's
Old Jul 7, 2003 | 07:14 PM
ek4ek9's Avatar
read this b4 changing spark plug cable
here's the link
http://www.vtec.net/articles/v...=8680
Old Jul 7, 2003 | 07:17 PM
2000CX's Avatar
Default Re: (granada_sun)
go ngk all around...
PFR6L-13 for platinum
BKR6E-11 for copper
HE64 for th wires
Old Jul 7, 2003 | 07:21 PM
Default Re: (ek4ek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4ek9 &raquo;</TD></TR><TR><TD CLASS="quote">read this b4 changing spark plug cable
here's the link
it'd help if that link worked meng
Old Jul 7, 2003 | 07:26 PM
2000CX's Avatar
i am also interested in seeing what this link says.
Old Jul 7, 2003 | 07:29 PM
DSeriesBeeKilla's Avatar
DO NOT....I REPEAT DO NOT run bosch plugs in your honda or any other honda...it will be a waste of your money b/c the car will run like ****.....NGK all the way......
Default Re: (99D16VTECCivic)
ttt
Old Jul 7, 2003 | 07:32 PM
FF-sean's Avatar
N G K
Old Jul 7, 2003 | 07:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granada_sun &raquo;</TD></TR><TR><TD CLASS="quote">bosch plat 4's....theyre $5/ea. but worth it IMO. </TD></TR></TABLE>
Old Jul 7, 2003 | 07:34 PM
Default Re: (ReaL JDM Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReaL JDM Eg6 &raquo;</TD></TR><TR><TD CLASS="quote"> N G K </TD></TR></TABLE>
sorry my finger keeps gettin' stuck...haha
Smith Wise's Avatar
NGK gets my vote, this needs to be a poll, NGK would be winning by a mile. Bosch are like PepBoys "top of the line" products. Might as well search around for some APC spark plugs.
I didn't know spark plugs offered hp gains, at least noticeable gains, but I guess every gain is notcible on a dyno. What car is being dyno in that example???
btw, someone needs to edit rather than "post-whoring"
edit: nevermind, i re-read, all motor d16 .............. see it's not so hard to edit
Old Jul 7, 2003 | 07:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99D16VTECCivic &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT....I REPEAT DO NOT run bosch plugs in your honda or any other honda...it will be a waste of your money b/c the car will run like ****.....NGK all the way......</TD></TR></TABLE>
dude ive been running boschs in my car for 3 months with no problems whatsoever.....why the nonsense?? I mean i realize NGK are stock plugs for hondas, but whats so bad about bosch?? i need the proof before i jump on the bandwagon...
Old Jul 7, 2003 | 07:38 PM
when i put bosch.....the name alone should scare you.....in my car it ran like **** ran over twice by a cement truck and once by a trash truck...that's just my opinion.....if the car ran good with bosch in it they would have put it in there when they built the car.....
2000CX's Avatar
so since everyone here LOVES ngk...what do you prefer...the coppers or the platinums? which runs colder?
Old Jul 7, 2003 | 07:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99D16VTECCivic &raquo;</TD></TR><TR><TD CLASS="quote">when i put bosch.....the name alone should scare you.....in my car it ran like **** ran over twice by a cement truck and once by a trash truck...that's just my opinion.....if the car ran good with bosch in it they would have put it in there when they built the car.....</TD></TR></TABLE>
not necessarily meng, i mean bosch is american...ngk is japanese......now that i think about it that should be more than enough reason right there...
but ill stick with them til they burn out......*Crosses fingers*
*edit*- i mean if theres something about bosch's that will smoke my engine, ill change em....i'd just like to see the proof..
Old Jul 7, 2003 | 08:10 PM
ELUD THS's Avatar
New User
copper., good conductors, but you got to change them everyother oil change.
Old Jul 7, 2003 | 08:15 PM
Moe's Avatar
Moe
Default Re: Spark Plugs for my b16a2, any suggestions???? (TwistedSI)
^ So tight....
Old Jul 7, 2003 | 08:25 PM
BackSideSA's Avatar
your such a tool....
Old Jul 7, 2003 | 08:33 PM
JSwiftNyc1's Avatar
its up to you man i say NGK all the way ..look at the difference on the tip itself i tried bosch once and they were great for about a month after that eeH they burn out ..i say just keep a set around as spare plugs just incase you need them ...then swapem for the ngks when u get the flow ..etcetc...peaz..
Old Jul 7, 2003 | 08:37 PM
youngkow's Avatar
That's right, don't get P+4's. My cars did not run like ****, but kept throwing cylinder misfire codes. It threw those codes on a stock civic lx engine, integra ls engine, and an accord v6 engine. I replaced the rotor, cap and plugs on all of them, and it still threw codes. When I changed them back to the stock NGK's, BAM! it wasn't throwing any more codes. I know the car wasn't running like ****, or detonating, or what not, but it was throwing codes because of those plugs. So imho, bosch platinum +4s suck a$$.
Old Jul 7, 2003 | 08:40 PM
Default Re: (youngkow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngkow &raquo;</TD></TR><TR><TD CLASS="quote">
That's right, don't get P+4's. My cars did not run like ****, but kept throwing cylinder misfire codes. It threw those codes on a stock civic lx engine, integra ls engine, and an accord v6 engine. I replaced the rotor, cap and plugs on all of them, and it still threw codes. When I changed them back to the stock NGK's, BAM! it wasn't throwing any more codes. I know the car wasn't running like ****, or detonating, or what not, but it was throwing codes because of those plugs. So imho, bosch platinum +4s suck a$$.</TD></TR></TABLE>
i dunno man, 3 months not a code or sign of slumpage yet.....
Old Jul 7, 2003 | 08:46 PM
Moe's Avatar
Moe
Stock plugs are NGK laser cut platnium.... and there like 13 dollars each. The OEM route is still expensive, but its your car and you money.... so go for whatever you want.
