Do Civic Dx's have a main relay under the dash like Civic Si's?
Old Jul 7, 2003 | 03:43 PM
sicivic's Avatar
Default Do Civic Dx's have a main relay under the dash like Civic Si's?
Just like the topic says. My buddy's 1990 Civic Dx won't start. It has spark but he's not sure about fuel. Is there a way to check to see if the fuel pump is working before dropping the tank? I just want to make sure that the main relay is working if the car has one. If it does, then it isn't clicking. Thanks
Old Jul 7, 2003 | 03:48 PM
mr. carpenter's Avatar
Default Re: Do Civic Dx's have a main relay under the dash like Civic Si's? (sicivic)
you should hear the pump whir when the key is turned. i'm pretty sure the main relay is under drivers side dash left of steering wheel.at least my std does.
Old Jul 7, 2003 | 03:57 PM
Hcivic88's Avatar
Default Re: Do Civic Dx's have a main relay under the dash like Civic Si's? (mr. carpenter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">you should hear the pump whir when the key is turned. i'm pretty sure the main relay is under drivers side dash left of steering wheel.at least my std does.</TD></TR></TABLE>
yup, under the dash and to the left. and like mr. carpenter said, when you turn the key to the "on" position, you should hear the pump kick in, then turn off.
Old Jul 7, 2003 | 04:01 PM
RCautoworks's Avatar
Default Re: Do Civic Dx's have a main relay under the dash like Civic Si's? (Hcivic88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic88 &raquo;</TD></TR><TR><TD CLASS="quote">
yup, under the dash and to the left. and like mr. carpenter said, when you turn the key to the "on" position, you should hear the pump kick in, then turn off.</TD></TR></TABLE>
My pump works fine but you can't hear it turn on. You can do this test to see if the pump is working.
http://www.binghamtonlife.com/...0.jpg
Old Jul 8, 2003 | 05:29 AM
Brandon Clifton's Avatar
Default Re: Do Civic Dx's have a main relay under the dash like Civic Si's? (90blackcrx)
or you can disconnect the fuel return line from the fuel rail/throttle body and see if the pump flows 7oz in 10 sec.
wvfarmboy
Feb 24, 2008 05:13 PM
EKHWhat
Mar 17, 2007 11:41 AM
hks_Racing
Dec 16, 2005 07:21 AM
wambus
Feb 12, 2004 08:40 PM
simike
Sep 16, 2002 05:05 PM
