OT: Need Help With Pictures (56k Maybe)
Old Jul 7, 2003 | 03:05 PM
Denny's Avatar
Default OT: Need Help With Pictures (56k Maybe)
well before, my fog lights worked, but the illumination didnt work and i could turn the fogs on at anytime. So i decided to work on it alittle more to make the illumination work. I got the illumination to light up when the city/lowbeams are on, but the fog light doesnt work now. here are some pics, maybe u guys can help me out.
Switch
Relay
Fuse Box
somebody please help me!!
Old Jul 7, 2003 | 03:28 PM
Denny's Avatar
Default Re: OT: Need Help With Pictures (Denny)
anybody?
Old Jul 7, 2003 | 03:35 PM
98R-1144's Avatar
i think you wired your relay wrong? i wired mine differently.. same setup, but the relay is different.. and mine work fine (fog only turns on/off if parking lights are on.. and the illumination works correctly... except it doesn't dim )
I have 86 going to ground
30 going to the battery
85 going to the switch
87 going to the lights
Old Jul 7, 2003 | 04:13 PM
Denny's Avatar
Default Re: OT: Need Help With Pictures (98R-1144)
still doenst work
Old Jul 7, 2003 | 04:18 PM
uNF$@#!'s Avatar
i dont think those connections to the fuse box are correct.... primarily your constant 12v power connection.
also, i would highly recommend putting fuse in that circuit...
Old Jul 7, 2003 | 04:26 PM
Denny's Avatar
Default Re: OT: Need Help With Pictures (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">i dont think those connections to the fuse box are correct.... primarily your constant 12v power connection.
also, i would highly recommend putting fuse in that circuit...</TD></TR></TABLE>
yes there is a 30amp fuse in the part from the constant from the fuse box to the relay. and and i believe thoughs are correct though. i used a test light. is there a way to test my actual fog light wiring and or switch in the foglighst switch?
Old Jul 7, 2003 | 05:03 PM
Denny's Avatar
help me out!
Old Jul 7, 2003 | 05:47 PM
poison's Avatar
Sent ya PM back
Old Jul 7, 2003 | 06:02 PM
Denny's Avatar
Default Re: OT: Need Help With Pictures (poison)
anybody else?
Old Jul 7, 2003 | 08:12 PM
Denny's Avatar
can anybody meet up and help me out?
Old Jul 7, 2003 | 09:07 PM
B2FiNiTY's Avatar
Very very nice pics! Someone definately help him out since his pics are so good.
Old Jul 7, 2003 | 11:50 PM
poison's Avatar
Default Re: OT: Need Help With Pictures (B2FiNiTY)
Talked to him via phone. I'll have to research the issue more with that being said.
But the resolution I gave you Denny should solve the problem. Plus it's as wired by factory as well.
Keep us posted, man.
rrepking
Jan 6, 2015 02:08 PM
TanaVP
Lighting
Sep 2, 2014 03:46 AM
Laz's EP
May 7, 2009 02:24 PM
myvtechits
Dec 1, 2007 02:47 PM
EM1VtecSi
Feb 28, 2005 07:11 PM
