B18C5 swap ....cheap
Ok I need to sell ASAP to fund other things. This setup has less than 1500 miles on it, the rings didn't seat correctly and I am considering selling as is. I am guessing the compression ratio to be somewhere around 12-5-1 and may even be higher. It dynoed 183 even with the leakage from rings. I will take more pics if I see interest in this thread. Ok here is what i have, and everything is still complete. I am asking $3700 as is for everything listed, if I get new rings then price will be more. It is out of the car and ready to go.
Block:
00 B18C5
ctr pistons on itr rods
Dc jdm 4-1 stainless header (can include testpipe w/o2 bung)
Head:
00 Si B16 head
cleaned up (not milled)
ported and polished
complete itr valvetrain
itr outer and portflow inner valve springs
portflow titanuim retainers
port matched itr intake manifold
itr throttle body
itr fuel rail and injectors
b&m fpr
str silver cam gears
polished valve cover, cut for cam gears
trans:
00 si (s4)
quaife LSD
act stage 2 clutch
chromoly 9lb flywheel
Block:
00 B18C5
Head:
00 Si B16 head
ported and polished
itr throttle body
b&m fpr
trans:
00 si (s4)
quaife LSD
act stage 2 clutch
