Escort Passport SR7 and Shifter ZR3
Just wondering if anyone has any experience with the installation of these two products in a G3 Integra . I plan on doing the installation myself, maybe with the help of some professionals at work. I'm worried about there being enough space in the front bumper for the sensors.
Information about these two products can be seen at Escort's website, including install manuals.
http://www.escortradar.com/sr7.htm
http://www.escortradar.com/zr3.htm
The front sensors are small. with the supplied brackets you can most likely screw it to between the plastic grille bars in your front bumper. It has supplied plastic brackets with the ends bending 90 degrees.
Make sure you take off the front and rear bumpers. you might want to thinking about pulling most of the interior apart before you start planning the install and pull off the front and rear bumpers. It will make it so much easier and the wiring so much stealthier. You can use the same grommet they use for the licence plate light for the rear sensor and just use the ones though the firewall for the front one.
just in case if you didn't know, if you are using the ZR3 with a shiftlink compatible radar/laser detector like an SR7 or 8500, you do not need to use the ZR3 display. When you turn on your ignition, it will turn on, beep and go into "sleep" mode.
Where are you planning to mount the sr7 display and mute button?
Serb
Mar 29, 2013 08:37 AM
jdmjim
Honda Civic (2006 - 2015)
Jul 23, 2009 01:26 PM
