Mugen Head gasket
Old Jul 29, 2001 | 11:59 AM
pong's Avatar
New User
Default Mugen Head gasket
Did anyone get any ponies out of a Mugen head gasket? If so, how many?Are there any better applications out there?
Old Jul 29, 2001 | 12:03 PM
slowerthanu's Avatar
New User
Default Re: Mugen Head gasket (pong)
I didnt get a pony . You will see about a 10 whp increase though
Old Jul 29, 2001 | 12:52 PM
Dipshit Dan's Avatar
Default Re: Mugen Head gasket (slowerthanu)
10 WHP??? I'd say more like 1 or 2.
EPGONZALEZ's Avatar
hahaha..with the us stock compression..you will see a slight increase in power..(approx .2 rise in compression) with the jdm spec 11.1:1 pistons..which the headgasket was designed for..you will see an even better increase.. (.4)
Old Jul 29, 2001 | 04:48 PM
Alaskan98ITR406's Avatar
New User
Default Re: Mugen Head gasket (EPGONZALEZ)
What kind of tuning would you need if you had the JDM ITR Pistons 11.1-1 and were going to put on the Mugen Head Gasket????
Old Jul 29, 2001 | 10:04 PM
mafay2's Avatar
New User
Default Re: Mugen Head gasket (Alaskan98ITR406)
Just make sure you put in 92+ octane gas and have the ecu tune for it, so the engine won't blow up due to high CR
Old Jul 30, 2001 | 12:44 AM
EPGONZALEZ's Avatar
Default Re: Mugen Head gasket (mafay2)
ive tuned with the mugen ecu and the stock ecu..prefer the mugen becuase you dont need the second o2 sensor..but power gains were minimal compared to stock ecu...the lowered vtec point on the mugen is about the only real strong point..the new raised compression loves some fuel..so get a vafc and a fuel pressure regulator and you should see some good numbers hope this helps
purposebuilt
Oct 1, 2018 09:48 PM
ANIAK'S_LUDE
Jun 14, 2008 02:06 PM
thegrayghost
Feb 22, 2005 04:31 PM
Nvious R
Apr 24, 2002 04:47 AM
