Overheating Accord >>>>>>>>>>>>>
Old Jul 6, 2003 | 06:34 PM
Mishkin's Avatar
Default Overheating Accord >>>>>>>>>>>>>
My '87 Accord keeps overheating. . It's not getting any coolant.. I just changed the T-Stat and it didn't help..
If it cracked the head or something what engines swap into a '87 4dr. body?
Old Jul 6, 2003 | 07:37 PM
Razor's Avatar
Default Re: Overheating Accord >>>>>>>>>>>>> (Mishkin)
maybe a bad head gasket
Old Jul 6, 2003 | 09:55 PM
Thrillhouse's Avatar
Default Re: Overheating Accord >>>>>>>>>>>>> (Razor)
check to see if your fans turn on? If not check your relays and fuses, also check your fan sensor switch. My friends 96 accord had the same prob and we fixed it by changing the fan sensor switch. good luck man
Old Jul 7, 2003 | 02:58 PM
sam187p's Avatar
Default Re: Overheating Accord >>>>>>>>>>>>> (Thrillhouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse &raquo;</TD></TR><TR><TD CLASS="quote">check to see if your fans turn on? If not check your relays and fuses, also check your fan sensor switch. My friends 96 accord had the same prob and we fixed it by changing the fan sensor switch. good luck man</TD></TR></TABLE>
I also new someone with the same problem..it was either a 4th or 5th gen accord. And for a quick fix till you get it checked out I believe your a/c or horn relay can be used to substitute your fan relay...if that is infact the problem. Good luck man.
Old Jul 7, 2003 | 06:03 PM
Stripped Honda's Avatar
99-0104
Default Re: Overheating Accord >>>>>>>>>>>>> (sam187p)
did you bleed the air out of the engine ?? sounds like a dumb question but alot of people dont bleed it and you will just have air in your engine and no water
Old Jul 7, 2003 | 06:10 PM
AsiAnVenOm's Avatar
did you know that your radiator cap is also a thermostat...? most people dont...
Old Jul 7, 2003 | 07:21 PM
Razor's Avatar
Default Re: (AsiAnVenOm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AsiAnVenOm &raquo;</TD></TR><TR><TD CLASS="quote">did you know that your radiator cap is also a thermostat...? most people dont...</TD></TR></TABLE>
yeah thats why different radiator caps can change the coolant efficiency rate.
Old Jul 7, 2003 | 07:24 PM
99-0104
its not a thermostat but when it has too much pressure (varies between what cap/what the manufacter recomends) it wil release the pressure weither it be coolant or air into the overflow bottle then when it cools down it sucks the coolant from the over flow bottle back in the radiator
i guess you can kinda call it a thermostat but i dont think i would ever call it one
Old Jul 8, 2003 | 07:03 AM
AccVic's Avatar
You may also want to check your radiator maybe get it flushed might cure the problem
gustavobt
Oct 17, 2018 07:50 AM
SuperSharpBlue
Oct 21, 2013 02:30 PM
2006_accord_own
May 30, 2011 07:40 PM
plumcrazebody
Sep 25, 2010 03:14 AM
Bird333
Sep 6, 2003 05:36 AM
