simple: which intake will fit w/o losing diameter?
I'm getting a cai. Would I get one for the car (crx) or engine (b17)? I figured for the car, but then what if the B17 uses a larger diameter intake? If it does, would it take much modification to make it fit? Or is the difference irrelevant?
The B series will have a larger diameter. If you still have the battery up front in the car, then get the one for the B17A('93 GSR). If you put the battery in the back, get one for a '95-96 del sol VTEC, it will fit well and also have a straighter path.
good luck,
Jared
good luck,
Jared
revvin9k
Nov 6, 2004 07:45 PM
popngen
Jun 11, 2004 04:21 PM
