Wanting to Run greddy E-manage
Hi..I am researching good fuel management setups..and the Greddy E-manage could be a future option. I tried reading up a lot on the greddy e-manage..however..I am unsure of all of what I will need to run this setup. My future boost setup will consist of:
b18b
custom 16g intercooled turbokit/ at around 6-8psi.
If i want to run the Greddy e-manage, what will be all the components that i will need besides the Emanage unit, Ignition Harness, Pressure sensor harness, injector harness, and pressure sensor to complete the setup? Will I need to convert to OBDI, upgrade my injectors, or do anything at all?
Khoi
b18b
Khoi
You got all the parts needed for the E-manage to work, but I assume you will be tuning the E-manage yourself? If so, you will also need to purchase the Support Tool to tune the E-manage on the laptop.
As for the ECU, you do not need to convert anything. The E-manage is a piggyback, so just follow the install instructions and it will work. You will need larger injectors...or else, how are you going to get more fuel?
Thanks..for the reply..and i dont' think i'll need the support tool..I was planning to take it in to a tuner, probably jotech to tune my car. Thanks again for the reply..maybe eventually, i'll get the support tool so that i may learn and master the art of tuning
Khoi
Modified by Sohc Driver at 9:19 AM 7/7/2003
Khoi
Thanks for the offer...im not ready to invest in it yet though....I still have to find a tuner for the midwest for it. I just found out Jotech doesn't tune the E-manage
Khoi
Khoi
