What wire off the O2 sensor do i connect the lead off my A/F gauge too?
NOT THE RED ONE!!!
j/k...there should be two that are either white or black (both the same color) and then one will be blue (or green) and another gray. or some combination of the two, it varies from sensor to sensor. Just turn the car on and probe the two wires of which there are only one color. The one that shows less than 1v will be the one you want. If you want to go from inside the car, I believe it is a red wire with yellow bands on the ecu harness...
it's been a while, but I think it was a white wire out of the ECU harness. Just tap the purple wire from the Autometer AF gauge to the white wire.
Do a search to confirm, I am 90% sure
stan
stan
LOL
Sweet thanks a bunch you guys. Got it working. Kinda neat. Also extremely inaccurate
jp
jp
NCHATCH
Aug 16, 2003 12:56 PM
2000_Si_On_Air
Jul 6, 2002 06:35 PM
dnt94civic
May 22, 2002 04:54 AM
