Tranny problem
Old Jul 5, 2003 | 02:42 PM
1sloaccord's Avatar
Default Tranny problem
Hey all, I got a problem. My car hesitates to go into gear. I hae a 99 Accord V6, auto tranny. My engine came one and i got a code 7 and a code 41 for the tranny. Cose 7 is the tps but my car idles fine it just doesnt go into that fast. I looked up code 41 and it says its the Defective Shift Control System - Fails To Shift, Stuck In 1st Or 4th Gears. Does anyone now where and what part i need. thanks
Old Jul 5, 2003 | 03:10 PM
H22 CD5's Avatar
Default Re: Tranny problem (1sloaccord)
if you have the extended warranty on the car, then i'd suggest that you bring it back to Honda, ASAP. the 6th gen accord v6 auto trannys are notorious for messing up. mainly due to poor engineering..kinda like the 5th gen preludes.
Old Jul 5, 2003 | 03:28 PM
1sloaccord's Avatar
Default Re: Tranny problem (H22 CD5)
Damn, its up. I got 80k on my car. Son of a motherlesss goat. Any ideas on where that part is
Old Jul 5, 2003 | 06:29 PM
Hondaaccordvtec's Avatar
Have you tried flushing your tranny fluid?
Old Jul 5, 2003 | 08:49 PM
Razor's Avatar
Default Re: Tranny problem (Hondaaccordvtec)
6th gen auto v6 trannies are junk, you have a defected unit.
Old Jul 5, 2003 | 10:00 PM
fluxion's Avatar
amin n'rangwa edanea
get your tps replaced first, since it has a direct effect on ecu controlled shift points. im sure your honda dealer can order it for you, but you can also order oem replacement parts from http://www.hondaautomotiveparts.com
Old Jul 5, 2003 | 11:22 PM
1sloaccord's Avatar
Default Re: Tranny problem (fluxion)
If my TPS is bad wouldn't it idle funny to begin with. My car idles fine, but it doesn't go into gear until bout 2k on the tach
Old Jul 6, 2003 | 05:26 AM
YeuEmMaiMai's Avatar
TPS may be functional at idle but messed up somwhere else......
ok guys for everyone that says the 6th gen trannies are junk, they took a poll over at v6performance.net (the old accordv6 page) and they found that the failure rates on the transmissions were not signifigantly higher (once they factored in the I drive like an **** or beat the tranny into submission factor)
Now saying that the units do have a higher failure rate than previous honda units and I think that has to do with GM helping honda in some of the design....Honda took the high road and offered 70K protection and so far it has worked. My friend has a '99 Accord V6 with 97K on the clock and that car runs like the day it was bought.....she does NOT dog the car..........
Old Jul 6, 2003 | 11:03 AM
EGPrelude's Avatar
didnt they extended the warranty to 7years 100,000 miles? or is that another car?
i maybe be wrong
Old Jul 6, 2003 | 12:52 PM
it was only 70K on the trans
Old Jul 6, 2003 | 01:47 PM
1sloaccord's Avatar
Default Re: (YeuEmMaiMai)
is the tps sensor the one rivited on the throttle body
Old Jul 6, 2003 | 10:10 PM
1sloaccord's Avatar
Default Re: (1sloaccord)
NE1 know where the TPS is located....ne1?
Old Jul 6, 2003 | 10:11 PM
AccordDriver92's Avatar
check your fluid
Old Jul 7, 2003 | 12:26 AM
1sloaccord's Avatar
Default Re: Tranny problem (AccordDriver92)
Its not the fluid, it is full. I got the codes from the ECU, how can it be the fluid.
Code 7 = TPS sensor
code 41 = Shift control System
Old Jul 7, 2003 | 04:35 AM
TPS has the throttle cable attached to it and it should be near opening on the intake.....you will have to remove the throttle cable to get to it...
Old Jul 7, 2003 | 09:37 AM
carolinaACCORD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sloaccord &raquo;</TD></TR><TR><TD CLASS="quote">Its not the fluid, it is full. I got the codes from the ECU, how can it be the fluid.
Code 7 = TPS sensor
code 41 = Shift control System</TD></TR></TABLE>
Even though the transmissions are electronically controlled, they're still hyrdaulic driven. If there isn't enough fluid it WILL have adverse effects on other functions.
Do a flush and refill it. If that still doesnt fix it, test the shift solenoids. There is also about 12347617631194632148973264 other things that can be causing this. But those are the most common.
Old Jul 7, 2003 | 09:51 AM
btlfed1's Avatar
Default Re: Tranny problem (carolinaACCORD)
I have a letter from honda them selves saying that they carried the warranty on the transmission to 7 years 100,000 miles not 70,000. The best thing is to call honda and ask one of the service managers what they warranty is.
Tmich91
May 25, 2015 05:47 AM
jimmyhat
Aug 28, 2007 03:56 AM
GRFMotorsports
Jun 6, 2004 01:40 PM
preludexl
Jul 21, 2003 05:42 AM
Nick H
Mar 19, 2002 05:14 PM
