Problem with my right fan not turning off
Old Jul 5, 2003 | 02:32 PM
jbentley's Avatar
Default HELP!! Problem with my right fan not turning off
I need a little help here. The fan on the right side does not turn off with the car. I know some times it stays on when it is hot, but it is staying on for up to 30 min before it is shutting off. Any body else have this problem?
-Jim
94 Accord ex.
ps, the fan only runs when the key is off. if I turn the key to acc, and the motor is not hot, the fan is off.
Modified by jbentley at 1:45 AM 7/6/2003
Modified by jbentley at 7:22 AM 7/6/2003
Old Jul 5, 2003 | 06:32 PM
Hondaaccordvtec's Avatar
Default Re: HELP!! Problem with my right fan not turning off (jbentley)
Sounds like you may have a cooling problem. Have you had to change the radiator or themostat yet or is it still the original one(s)?
Old Jul 5, 2003 | 09:58 PM
jbentley's Avatar
Default Re: HELP!! Problem with my right fan not turning off (Hondaaccordvtec)
Still original, but runs in the normal operating temp, the fan will keep running long after the radiator is cool. I am hoping someone else has had this problem and has the solution.
Old Jul 5, 2003 | 10:13 PM
fluxion's Avatar
amin n'rangwa edanea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbentley &raquo;</TD></TR><TR><TD CLASS="quote">Still original, but runs in the normal operating temp, the fan will keep running long after the radiator is cool. I am hoping someone else has had this problem and has the solution.
i had the same problem...my fan would keep running for about 15 minutes after i shut the car off...it was especially annoying for me cuz it would keep setting off my alarm. it stopped doing this after i change my radiator fluid....still does it every now and then but only for a couple minutes at the most.
dont assume you dont need to change the radiator fluid because of your car's running temperature...when your car is moving the airflow plays a major part in keeping the engine cool.
Old Jul 5, 2003 | 10:20 PM
jbentley's Avatar
Default Re: HELP!! Problem with my right fan not turning off (fluxion)
I could give that a try and see how it works. I have never even heard of this problem before this.
Thanks.
Old Jul 6, 2003 | 05:43 AM
YeuEmMaiMai's Avatar
if changing the coolant does not work, it might be time for a new TEMP sending unit for your ECU. Most cars use two sepearte sending units, one for the guage, and one for the egnine management system.
Kenneth723
Jun 9, 2019 07:38 PM
redline09
Aug 25, 2010 05:56 AM
jth8448
Feb 5, 2008 09:55 PM
American.Graffiti
10
May 29, 2007 05:06 PM
hondaaccord94
Jan 5, 2007 11:53 AM
