does any one have a pic of RSX with a short ram intake?
Old Jul 4, 2003 | 01:13 PM
rsx-lake's Avatar
Default does any one have a pic of RSX with a short ram intake?
i installed my intake to my rsx, but everyone told me the intake is sucking the hot air in from the engin, so, any pro can show me a pic of the right way to install it.. thanx
Old Jul 4, 2003 | 01:37 PM
iam7head's Avatar
Default Re: does any one have a pic of RSX with a short ram intake? (rsx-lake)
great, Um..rsx/ep3 forum??
short ram intake should suck in hot air from the engine, it's design that way.
they are saying that not because you insalled it wrong but i think they are trying to tell you to get a CAI.
Old Jul 4, 2003 | 11:02 PM
rsx-lake's Avatar
Default Re: does any one have a pic of RSX with a short ram intake? (iam7head)
r u sure bout this..??
Old Jul 5, 2003 | 09:30 AM
rsx-lake's Avatar
help plzzzzzzzzzzzzzzzzz
Old Jul 5, 2003 | 09:54 AM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsx-lake &raquo;</TD></TR><TR><TD CLASS="quote">r u sure bout this..?? </TD></TR></TABLE>
Yes, what iam7head said is exactly right. All short-ram intakes suck in hot enginebay air unless the filter is enclosed in some sort of box or has a shield around it. I'm sure you installed it correctly.
Old Jul 7, 2003 | 11:59 AM
rsx-lake's Avatar
Default Re: does any one have a pic of RSX with a short ram intake? (Daniel)
umm...thanx...but is it better if the intake can suck in cold air? cause i just installed a heat shiled for block the heat from the engin, is it good?
Old Jul 7, 2003 | 12:48 PM
Regal's Avatar
Ladies and gentlemen we are floating in space...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsx-lake &raquo;</TD></TR><TR><TD CLASS="quote">umm...thanx...but is it better if the intake can suck in cold air? cause i just installed a heat shiled for block the heat from the engin, is it good? </TD></TR></TABLE>
Yes, it's much better for the intake to suck cold air. Why didn't you just buy a cold air intake? It'd be a lot more effective and less of a hassle...
As for the heat sheild, I guess it depends on how effective it is....?
Old Jul 7, 2003 | 01:32 PM
itsallmotor's Avatar
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
Default Re: does any one have a pic of RSX with a short ram intake? (Regal)
I don't think heat shields are nearly as effective as a cold air intake just because a metal heat shield will just heat up itself and conduct that heat to the intake air. I wouldn't worry about it too much though, the couple degrees difference is not going to make your car a rocket by any means
Old Jul 7, 2003 | 02:12 PM
iam7head's Avatar
Default Re: does any one have a pic of RSX with a short ram intake? (hondavtecfanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondavtecfanatic &raquo;</TD></TR><TR><TD CLASS="quote">I don't think heat shields are nearly as effective as a cold air intake just because a metal heat shield will just heat up itself and conduct that heat to the intake air. I wouldn't worry about it too much though, the couple degrees difference is not going to make your car a rocket by any means</TD></TR></TABLE>
i think scc or some auto mag. ran a test with rsx on dyno, they use all the cai they can find in US(well, brand name intake in the US)
the heat shield from injen actually make the temp. of the tube run hotter and of course, lower the power.
time to save up for DC or aem CAI now..
Old Jul 7, 2003 | 03:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
exactly if you see temp readings from one of the companys its probably when the car has just barely been started so of course the metal is still cold, but like iam7head said scc did that test on the injen intake+shield for the rsx and it does heat up, I trust SCC's judgement for sure
Old Jul 7, 2003 | 04:57 PM
Archidictus's Avatar
Unceasing Measure
The AEM CAI for the RSX-S is a massive PITA to install, but makes incredible gains. If you're going to get a shortram, you might as well just cut up the bottom of your airbox and get a K&N drop in, because you're not getting anything more than that for your $215.00.
Old Jul 7, 2003 | 09:56 PM
rsx-lake's Avatar
umm...thanx u guys! u guys are pro...
so, do u guys think i should change to AEM SRI ? or just keep my short ram? how much diff i can make if i change it?
Old Jul 8, 2003 | 01:37 AM
Regal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsx-lake &raquo;</TD></TR><TR><TD CLASS="quote">umm...thanx u guys! u guys are pro...
so, do u guys think i should change to AEM SRI ? or just keep my short ram? how much diff i can make if i change it?</TD></TR></TABLE>
Definitely go for an AEM CAI...the cold air intake makes a lot of power on the K-series motor, and the short ram I think gains about 3whp max...I've actually seen tests where the short ram loses power compared to stock.
Think about....the filter is almost in the same spot it used to be, so really the only benefit is the better air filter, ya know? The CAI put the filter near the ground where it can suck in outside air.
Old Jul 8, 2003 | 02:30 AM
The Factor's Avatar
i would never get a SRI for k20...go for the cai man
91tegraRS
Mid-Atlantic (Sales)
Jul 1, 2008 05:49 AM
03RSXTypeS
Feb 4, 2008 04:32 PM
StuDizzle
Nov 21, 2005 08:41 PM
jdm.ej
Acura TSX
Jan 23, 2005 06:12 PM
Nick H
Jan 17, 2002 07:11 PM
