b16a wiring in 91 crx si
Old Jul 28, 2001 | 03:52 PM
GeeSeeR's Avatar
New User
Default b16a wiring in 91 crx si
I just got a crx with a 16a swap done, problem is the wiring was done wrong. Where can i get a diagram of how all the wires should be connected, also i heard that you need to wire 2 or 3 extra wires in on the harness, is this true?
Old Jul 28, 2001 | 07:02 PM
tysir's Avatar
New User
Default Re: b16a wiring in 91 crx si (GeeSeeR)
yeap you got to wire at least 4 wires. if your is a si its will only be 4 wires. no cutting. just extra pins that you needs. vtec selinoid, oil pressure, knock sensor, and 2nd O2 sensor. everything should be so much the same. you lucky you have it easy.
Old Jul 29, 2001 | 05:05 AM
GeeSeeR's Avatar
New User
Default Re: b16a wiring in 91 crx si (tysir)
thanks for the reply
Old Jul 29, 2001 | 08:23 AM
WuShu's Avatar
New User
hey can you guys explain the wiring for me? i have a 91 si crx and am gonna do the b16a swap, i already got the engine but need a little more detail with the wiring, to make sure i have it down right.
1stGenHmlae
Mar 5, 2007 06:42 PM
pepper
Jun 23, 2004 09:44 AM
racerxadam
Jan 3, 2002 01:36 PM
