Good Honda\Acura dealers in Atlanta
Does anyone know of a good Honda\Acura dealer in Atlanta that also provides loaner or rental cars? I need my transmission fixed ASAP! Second gear is becoming difficult to go into, I think either the syncro is bad or the shift fork is bent slightly. Either way, I need it fixed. I have a 2001 Prelude with about 9300 miles on it, so it warranty work. Any and all suggestions are appreciated.
P.S. If they are mod friendly that helps, my car has Koni Yellows on it. I dont see that being a problem though, but you can never tell with service departments.
Call up the dealer you bought the car from and tell them that you need a car while yours is in the shop. Even if they don't normally provide a loaner, if you tell them you need a car, they should rent you one. Also, if they give you crap about the Koni Yellows (although replacing shocks is something you have to do eventually anyway), aftermarket parts only affect warranty if they are the cause of the problem (ie hydrolock with a CAI)
