Bought a 99 Accord, give me some motor basics:::
Old Jul 3, 2003 | 09:35 PM
White 99's Avatar
Default Bought a 99 Accord, give me some motor basics:::
99 Accord EX, 3.0 Vtec........
Can anyone give the numbers (size, type, HP, etc) and the goods and bads of these motors?
TIA
Old Jul 4, 2003 | 10:56 AM
slow99accord's Avatar
Default Re: Bought a 99 Accord, give me some motor basics::: (BlkCiv)
You bought a nice car. I should know i have the same one. The engine makes about 200 hp but the auto tranny blows *** cuz it doesnt shift when ur racing. And if ur shifting through the gears urself u might wanna watch out cuz sometimes the check engine light will come on. But ive never had any other problems with it so good luck.
Old Jul 4, 2003 | 11:10 AM
FREAKquency04's Avatar
you have the J30a1 engine which puts out about 200 at 5500 hp im not shure about the hp to the wheels. the max torque you get is 95 at 4700. its a SOCH and it has vtec. your compression ratio is 9.4:1 and your displacement is 2997. Your bore stroke is 86.1 x 86.1. the good thing is that your car has alot of horses for an accord for that year stock. the bad part is that its an automatic trany. one of the other draw backs is that the accord its self is very heavy. but other than that is a pretty dayme good car. i have a 2000 4cyl and a 2002 V6 and im very happy wid both!!
Old Jul 4, 2003 | 11:15 AM
iam7head's Avatar
Default Re: Bought a 99 Accord, give me some motor basics::: (AcCorDH22ARaCeR)
check the seat belt and the cd player when you buy it.
Old Jul 4, 2003 | 11:28 AM
YeuEmMaiMai's Avatar
according to Car and Driver it is 151HP at the wheels
Old Jul 4, 2003 | 12:26 PM
Crono139's Avatar
Default Re: Bought a 99 Accord, give me some motor basics::: (YeuEmMaiMai)
That's it? That's a lot of power loss.
Old Jul 5, 2003 | 08:00 AM
White 99's Avatar
Default Re:
thanks guys!
Old Jul 9, 2003 | 09:52 PM
Doom878's Avatar
Default Re: Re: (BlkCiv)
I've seen them dyno like 155hp-157hp over at http://v6performance.net. With intake, headers, exhaust you'll be up to like high 160-low 170s. You might run like mid 15s. You really can't abuse the tranny because it WILL blow if abused. You really can't go crazy with mods due to the tranny and lack of availability. You can get a supercharger as well for about $3800. Nitrous is a nice cheap alternative. I would recommend also the UR pullies and Acura CL-S camshafts. Just make sure you do your tranny fluid changes religiously.
Old Jul 9, 2003 | 10:39 PM
Heat's Avatar
Nah, the 151 HP must be for the 2.3L engine (the inline 4). Edmunds lists that at 150 HP.
The 3.0 V6 engine is listed at 200 hp, 195 ft-lbs of torque, and 5500 rpm of max horsepower.
http://www.edmunds.com/used/19...Honda*
Follow the links on the left for other information about your car.
Unfortunately, in 1999 Honda did not make the V6 with manual transmission, which is why I went with the inline 4. With a manual, the I4 is actually somewhat sporty and jumps when I tell it to jump.
Old Jul 9, 2003 | 11:26 PM
Doom878's Avatar
Default Re: (Heat)
Heat,
We are referring to horsepower at the wheels. This is true hp. 200hp is rated at the crank. But when you measure the actual hp it loses power when the power transfers to the wheels. An i4 Accord probably dynoes in the 120s-130s hp.
Old Jul 9, 2003 | 11:52 PM
iam7head's Avatar
Default Re: (Doom878)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doom878 &raquo;</TD></TR><TR><TD CLASS="quote">Heat,
We are referring to horsepower at the wheels. This is true hp. 200hp is rated at the crank. But when you measure the actual hp it loses power when the power transfers to the wheels. An i4 Accord probably dynoes in the 120s-130s hp.</TD></TR></TABLE>
well said, 98-02 v6 never come with auto tranny
samething to the 5th gen v6.
not until the 7th gen they give a 6speeds for the v6
Old Jul 10, 2003 | 07:25 AM
Heat's Avatar
Ah, I see. I still have more to learn, thanks for the quick lesson.
Old Jul 10, 2003 | 10:29 AM
Doom878's Avatar
Default Re: (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
not until the 7th gen they give a 6speeds for the v6</TD></TR></TABLE>
I think you meant manual tranny.
No problem Heat. We all learn at one point.
Old Jul 10, 2003 | 12:36 PM
p0pe's Avatar
You mean you didn't research anything about the car before you bought it?
Try google.com, no offense. There's also a search feature in the upper-left hand corner of this website. There's plenty of good sites out there with this general info.
Old Jul 10, 2003 | 12:48 PM
Doom878's Avatar
I'll say it once and I'll say it again.
<U>http://www.v6performance.net</U>
Old Jul 12, 2003 | 10:51 PM
SIMATIC's Avatar
NOS--poor mans super charger
Jose Ibarra
Aug 3, 2017 04:52 PM
KellyKoning
Transmission & Drivetrain
Feb 8, 2016 10:27 AM
theeboiivince
May 13, 2009 09:03 PM
Rpizzle
Apr 24, 2005 07:12 PM
icon_race_eg
Jan 3, 2004 07:23 PM
