HELP- sqeeuking steering wheel
Old Jul 3, 2003 | 11:40 AM
stripes777's Avatar
Default HELP- sqeeuking steering wheel
yesterday, my car started squeeking in the steering wheel, well, it seems more like inside the car, the area where the steering wheel turns. i was wondering if there is like a bearing or something that has to be lubed up or replaced.
any help would be grat, thanks
Old Jul 3, 2003 | 12:26 PM
B16b2b's Avatar
Default Re: HELP- sqeeuking steering wheel (stripes777)
you may need to add some grease to the steering column. pull it off and see!!!
Old Jul 3, 2003 | 12:49 PM
stripes777's Avatar
how do i do that. is it simply by pulling off the plastic cover behind the steeering wheel and bam? or there is more to it?
Old Jul 3, 2003 | 12:56 PM
crashoveride's Avatar
hey mine "did" that....but it went away by itself. just leave it
Old Jul 4, 2003 | 05:08 PM
stripes777's Avatar
doesnt seem like its gonna go away. so any one know how to add grease to the steering column?
Old Jul 5, 2003 | 10:04 AM
fathergoose's Avatar
check to see if the noise doesn't come from your ball joints
Old Jul 5, 2003 | 11:38 AM
tangb2023
Guest
Posts: n/a
Default Re: (stripes777)
behind steering wheel. there are 2 plastic piece. left and right side to take airbag off. use a torx bit to take it off.. then the airbag comes off.. in the middle behind the airbag there is a hex nut.. take it off and lube all metal with grease...
Danielsb20crx
39
Jan 6, 2013 01:02 PM
M-benz
Apr 22, 2012 07:56 PM
theeogflip
May 22, 2007 11:28 AM
cannon_man
Feb 17, 2004 03:30 PM
mRek9R
16
Jan 30, 2003 11:45 AM
