Air bag light stays on.....?
I swapped out my EX instrument cluster for an Si cluster and the airbag light won't go off. I've tried disconnecting the battery, the airbag connection in the bottom of the steering wheel, the fuse, everything is good, but the SRS light stays on. Anyone have any ideas? If not, I'll just deal with it.
Mine's on 24/7 since I run a Sparco wheel. To reset it you either have to hook up an Honda scanner to the ABS computer and reset it....or take the bulb outta the dash.
RineRacing
20
Jan 24, 2003 06:55 AM
