Anyone running limiting straps?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AussieB20vtec »</TD></TR><TR><TD CLASS="quote">As per title, anyone running limiting straps on their front ends to prevent lift???
After feedback and advice.....</TD></TR></TABLE>I used to think this was the best thing to do but now think it does not work and only helps unload the wheels.
thanks fabman. since those don't work what does work? shocks with adjustable rebound/compression? i'm guessing you want the front to have soft compression and hard rebound, and for the back you want hard compression and soft rebound, when running no wheelie bars. any hints on front spring weight? thanks again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AussieB20vtec »</TD></TR><TR><TD CLASS="quote">Thanx hmmmm gotta get better 60's.</TD></TR></TABLE>
what's your best 60', on the azenis?
u do a burnout with the azenis, to heat them up? my best with the azenis is actually a 2.1 on the b20, but i'm hoping to hit 1.9's the next time i hit the track! have you figured out why your 60' time, went up with the b20 set up!
The azenis were heat cycled to death. I had to use them when dynoing as they were the only tyres that size that I had. I've only done three passes with the B20 so practice would probably get the times back down but I got crappy Nitto DR's now
i'mnna need some practice, i haven't been to the track for about 4 months. my tranny too a dump on me, and i have been trying to put my hands on a gsr ys1 but it hasn't happen yet! i think you'll be in the 12's pretty soon, like in the next few times you hit the track
i heard the straps help stop wheel hop ...is this true or do they not work? ...and are the limiting straps on summitracing.com the same strap you guys are talking about?
EJ8chu
Feb 24, 2008 10:17 AM
