Rebuilt motor, smokes but good compression
Old Jul 2, 2003 | 10:53 PM
AzG35's Avatar
Default Rebuilt motor, smokes but good compression
I just finished rebuilding my B18C1 bottom/B16a head combo. I put in JE 11.5:1 CR 81.5mm pistons, new rings, and fresh bearings and bottom end stuff. I got it running. The oil pressure is good, I've only put 10 miles on it so far. But it smokes. It looks like blue smoke, which I know is oil. Is this normal for a fresh motor? I did a compression check and it read 240psi on 6 cranks on each cylinder. Could the oil rings not be seated yet? Or could stuff be burning off from the head? I didn't do anything to the head except clean up the carbon with some ATF and carb cleaner. The head was fully serviced about 8000 miles ago. Other than the smoke the car runs good. Any input? Thanks in advance...
Old Jul 2, 2003 | 10:59 PM
IN VTEC's Avatar
Default Re: Rebuilt motor, smokes but good compression (AzSi22)
What were your ring end gaps, bore taper, and piston-to-bore clearances?
Old Jul 2, 2003 | 11:03 PM
AzG35's Avatar
Default Re: Rebuilt motor, smokes but good compression (IN VTEC)
Piston to wall was .0040" or so, it was a little over the .0033", but well within standards according to JE. The ring gaps were set at .015" for top, .016" for second and the oil rings were left alone, they were closer to .017". I don't know what bore taper is, please explain and I will probably know.
Old Jul 2, 2003 | 11:18 PM
IN VTEC's Avatar
Bore taper is the difference in diameter b/w the top and bottom of the bore.
Old Jul 2, 2003 | 11:19 PM
AzG35's Avatar
Ok, thats what I was kinda thinking. The taper was very little, it was pretty even at the bottom and at the top. Probably no more than .0002 difference
J_Boost
Mar 21, 2012 02:35 PM
Rikaro
Nov 5, 2007 11:40 AM
jeremy.
Sep 26, 2003 07:19 AM
AzG35
Jul 3, 2003 03:23 PM
B18EG6
Dec 30, 2002 08:17 PM
