pressed ARP rod bolts?
Old Jul 2, 2003 | 10:41 PM
untitled's Avatar
Default pressed ARP rod bolts?
a local shop told me that you have to press these to install them correctly. is anyone familiar with this. i need to before i put together my new ls/vtec.
_______
Old Jul 3, 2003 | 09:16 AM
granada_sun's Avatar
the pins that go into the piston heads have to be machined if they're OEM.....theyre a little too long and have to be shortened....
Old Jul 3, 2003 | 11:37 AM
Rocket's Avatar
Default Re: pressed ARP rod bolts? (88crx91integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra &raquo;</TD></TR><TR><TD CLASS="quote">
_______</TD></TR></TABLE>
This means that the piston pins are a press fit to the rods. So the rods should be heated so they can be pushed through the small ends of the rods. Just have you machine shop do this and let your worries be gone.
Old Jul 4, 2003 | 05:30 PM
smokey2.0's Avatar
i think he was asking about the rod bolts, not the piston rod! i would also like to know, if you can just screw them in?
Old Jul 5, 2003 | 07:41 PM
AzG35's Avatar
Default Re: pressed ARP rod bolts? (smokey2.0)
I did them by hand and haven't had any problems. Its a good idea to get the rods resized once you do that though.
Old Jul 5, 2003 | 09:09 PM
F1Spec's Avatar
Default Re: pressed ARP rod bolts? (AzSi22)
yes u have to have them pressed in if u have ls rods.
i paid my local machine shop to do it.
Old May 15, 2004 | 10:34 AM
notsure's Avatar
Default Re: pressed ARP rod bolts? (s2geezy)
how much does something like that cost. i want to have a good idea so i dont get ripped off by someone. I am just putting on pr3 pistons on ls rods and arp rod bolts in the rods. rough estimate?
shadydb7
Apr 25, 2008 03:45 PM
SiBuddy00
Feb 28, 2005 01:06 PM
Power Rev Racing
Sep 22, 2004 07:34 PM
hondaguyef
12
Jun 16, 2004 03:59 PM
riceball777
10
Oct 14, 2003 11:56 AM
