ls/vtec Q's
The motor is running real strong. But it leaks oil. After searching for hours I've conclude its leaking from the head gasket. Im not having any cooling problems or fuel problems. I did a search and found that if the vtec port is not matched correctly, oil will leak. I just need to know what i can do to fix this. thanks alot. BTW, the motor was just recently finished (only one oil change) Maybe 2500 on the rebuilt motor.
AHHHH!!!!!! I HAD THE SAME PROBLEM!!!! ITS SOOO ANNOYING!!. just bring it to your local tuning shop. that's what i did and they fixed that shizz right away. my problem was wit da tap into the head. it was the wrong size so oil was everywherez. might be the same thing for you where you just need a different tap. once you get that fixed the vtec pulls harder. haha hope i helped.
