help with idle....already search plz
my friends and I put back my head back on the block after it got port and polish.
after everything is back on i started the car and the idle was really rough. We did a valve adustment and the idle got better but not normal. After another adjustment the next day it was still the same. i was wondering if you guys have any suggestions on what to do or to check?
btw if its help, i had my shop port and polish, port flow inner with type r outter, itr intake valves and i put on a spoon headgasket.
what is your setup? check all your vaccum lines. spray you iacv with carb cleaner and cleans your screens on it.....
Also try and get the air bubble out of the coolant lines. Just take the cap off and let the car idle for a couple of minutes. If not that then what the others said. Good luck.
honcrf150
13
May 29, 2012 10:28 AM
del sol b18c
Sep 10, 2007 11:43 PM
