Weird Idle = Vacuum Leak??
Old Jul 2, 2003 | 08:20 PM
CivicDXR's Avatar
Default Weird Idle = Vacuum Leak??
heres the scoop... my D16Y7 has been acting funny... when I am driving normally (or harder for that matter), and then let go of the gas in any gear, the engine seems like its giving gas almost like I'm on the gas pedal slightly... before, when I would be in gear, and everything was working fine, when I would let go of the gas, my A/F meter would go out under completely lean (which i heard its supposed to)... but now when I let go of the gas, the A/F is still bouncing around... and when I put it in neutral to stop, it revs for a bit close to 1500-2000rpms, then drops down to 800rpms where it should be...
I've looked around and alot of people that have the same sort of problem are being told to look for a vacuum leak, so I've decided that I'd change all my hoses anyway... so my questions are:
1) which hoses need to be changed/looked at?
2) does the vacuum hose connected from the engine/intake to the brake booster need to be looked at as well (the 1-way hose with the PCV valve in it)? I think i should state that when I'm stopped and its at 800rpm, when i pump the brake, the rpms start going up again...
3) what else other than a vacuum leak could this problem be??
as you can tell, I'm getting really annoyed and frustrated with it and plans for a turbo were going well until this happened (there's no way I'm turboing anything until I get this fixed). Any help at all would be appreciated...
Thanks in advance...
CivicDXR
Old Oct 10, 2003 | 01:28 PM
tegboi's Avatar
Default Re: Weird Idle = Vacuum Leak?? (CivicDXR)
bump.. i have this problem too.. need to find out what to look at.. or get a update if you've already fixed the problem..
Old Oct 10, 2003 | 04:17 PM
TeStUdO's Avatar
check all the vacuum lines, especially the one coming from the brake booster.
abmerop18
Jul 16, 2006 07:10 AM
civiclxb16a
11
Apr 27, 2005 06:20 PM
DAguyLS
Apr 19, 2004 07:14 PM
DevinW
Apr 28, 2003 06:26 AM
jdm169
Feb 9, 2003 07:24 AM
