TONS of integra/ B series parts for sale, stock and aftermkt... moving on from my integra to a new p
Old Jul 2, 2003 | 06:39 PM
habitforming's Avatar
Default TONS of integra/ B series parts for sale, stock and aftermkt... moving on from my integra to a new p
B16A1 PR3 head $300 (bare)
Skunk2 B16 intake manifold $200
B16A1 throttle body (PR3) $50
GSR water pump (5k miles) $30
GSR oil pump (12k miles) $30 SOLD
USDM Integra Type R pistons, 0.25mm overbore (P73-A0). converted to floating pin and LS rod, if you are doing LS/vtec conversion, this is what you need! $150
Eagle connecting rods $250 SOLD
z10 Engineering block girdle $200
USDM Integra Type R intake valves $75
Crower Titanium retainers & Honda keepers(12k miles) $100
Crower Dual valvesprings (12k miles) $200
Crower 63402 camshafts (12k miles) $400
Micropolished, balanced crank $150
Hondata intake manifold heat shield $35 SOLD
Lightened stock flywheel (~13lb) $30
DC Sports DAC intake w/ k&n filter $40 SOLD
JUN 4-2-1 header $400 SOLD
Catco 2.5" x 12" high flow catalytic converter $100 SOLD
Tanabe Hyper Medallion 60mm cat back exhaust $400 SOLD
AEM underdrive pulley set $100 SOLD
AEM adjustable cam gears $125
B&M fuel pressure regulator / gauge $50 SOLD
NGK spark plug wires $20 SOLD
Energy Suspension torque mount inserts $20
B&M Pro Edge short shifter $50 SOLD
Suspension Techniques front sway bar $75
Suspension Techniques rear sway bar $75 SOLD
Tenzo R front upper strut brace $50
DC Sports rear lower tie bar $60 SOLD
Ground Control coilovers $200 SOLD
Tokico Illumina 5 way adjustable shocks $200 SOLD
Full camber kit front and rear $100 SOLD
16" 5Zigen Becketts FN-01R C with 205/45R16 Michelin Pilot SX GT $900 FIRM
New brembo blanks (all 4) $100
Metal Masters brake pads $50
Mugen program PR3 ECU $250
Apex'i V-AFC $225
MSD Sport Compact Ignition $125
GSR gauge cluster $100 SOLD
JDM 1 piece headlights $150 SOLD
Momo Pedals $60
Alpine ERE-G190 $150
Make an offer on everything below (i have pictures available of everything):
B16a intake manifold, glass beaded and hot tanked
B18a1 cylinder head, intake manifold, throttle body
B18a1 pistons/rods
B16a1 intake valves (about 40k miles), will sell any qty
B16a1 Ti retainers/keepers (i do not know what brand they are... came with engine)
B16a1 valvesprings (dual intake, single exh)
B16a1 cam gears
B16a1 5 million series cams
B18a Fast Idle Valve
B18a fuel rail
B18a oil pan, pickup, windage tray
B18a right side cover (goes behind flywheel)
B18a thermostat housing
B18a water pipe
B18c5 pistons/pins, P73-A0, widened for LS rods
Prothane rear motor mount insert, i think it's for Auto trans
Streetwires battery post terminal with 2-4ga coated brass connectors
misc power steering brackets... i will send pic so you can determine if it's what you need
ITR lower header bracket (from block to header flange) NEW
the website for my car is at http://home.insightbb.com/~hab...a.htm you can see many pics there
many parts that come off of my car directly i will require the stock replacement for so i can still sell the car as a whole. i am not parting out the car itsself!
email me at andy_feger@hotmail.com for fastest response. most prices are negotiable within reason, no lowballers and please only contact me if you are SERIOUS. it gets very difficult to keep up with all the emails that pour in. also please include the part you are interested in in the SUBJECT of your email to make things easier for me.
thanks
Modified by habitforming at 1:14 PM 7/4/2003
Old Jul 4, 2003 | 09:14 AM
Default Re: TONS of integra/ B series parts for sale, stock and aftermkt... moving on from my integra to a n
updated what has been SOLD
1clnef9
Jun 9, 2011 12:02 PM
jksmith
Sep 16, 2009 05:27 PM
siR cr-x
Mar 24, 2007 04:27 PM
asubennett
Nov 3, 2005 04:59 PM
habitforming
Aug 9, 2003 08:06 AM
