suspension setup under 1grand?
Old Jul 27, 2001 | 09:34 PM
Ibuprofen's Avatar
Default suspension setup under 1grand?
i need to decrease the wheel gap now that i got wheels. whats a good spring/shock setup that is superior to the stock R suspension for under 1g?
Old Jul 27, 2001 | 10:04 PM
CheezeFrog's Avatar
Default Re: suspension setup under 1grand? (ITyp3R)
Koni Yellows & Ground Control coil overs.
Old Jul 27, 2001 | 10:54 PM
BoM's Avatar
BoM
Default Re: suspension setup under 1grand? (CheezeFrog)
yep koni yellows and custom ground controls...or u can find some expensive springs....do a search.....
Old Jul 28, 2001 | 03:53 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
a spring/combo superior to itr for under a grand? nope. not possible. i would put a larger rear bar on it for about $360. if all you want to do is slam it, get a pair of cheap coilovers. but, the stock itr suspension is absolutley excellent. i just spent over $2,500 to improve mine, so improving will not be cheap.
Old Jul 28, 2001 | 07:05 AM
LRAO's Avatar
Default Re: suspension setup under 1grand? (rodney)
I think this is a GREAT set-up:
Bilstein Sport shocks ($500-ish)
kg/mm springs ($240-ish)
Loc
Old Jul 28, 2001 | 07:44 AM
Ibuprofen's Avatar
well, i dont exactly want the "slam look", just something that decreases the current gap by 1 1/2 inch. And to spend 2500$ on suspension mod is not justifiable imo, unless i track my car every weekend. i'm thinking of going w/ the koni yellow/eibach setup, any experience w/ this setup?
Old Jul 28, 2001 | 08:02 AM
itrhybrid's Avatar
I have been talking to a guy at a local shop here and he recommends GAB. They have a set of coilovers that run about 850/set I think. Adj. shocks and threaded spring perch gives you some room to play around.
James
Old Jul 28, 2001 | 08:18 AM
TypeRdude's Avatar
Default Re: suspension setup under 1grand? (itrhybrid)
I have the koni yellows on mine, with skunk2 coilovers. Handles well. I would say go with the ground controls, I'll be switching to them soon myself. KONI SHOCKS: http://www.diabloautosports.com/prod...roducts_id=305 Ground controls: http://www.diabloautosports.com/prod...roducts_id=610
Old Jul 28, 2001 | 09:45 AM
Hooch'n's Avatar
Default Re: suspension setup under 1grand? (TypeRdude)
Koni Yellows will drop you an inch.
Old Jul 28, 2001 | 12:26 PM
Ibuprofen's Avatar
Default Re: suspension setup under 1grand? (8400-RPM)
hows the bilstein's incomparison w/ the koni's?
Old Jul 28, 2001 | 01:25 PM
Hooch'n's Avatar
Koni shocks and Tokico shocks you can adjust. Bilsteins you can't adjust.
Old Jul 28, 2001 | 03:13 PM
Sinitron's Avatar
True, they aren't adjustable, but they are valved ultra-stiffy 'sport' rather than HD.
Which brings up the point... if someone just wants to reduce his wheel gap an inch... does one really need adjustable shocks + coilovers?
just slap some H&R springs on there and be done with it.
Old Jul 29, 2001 | 09:19 AM
Hooch'n's Avatar
Default Re: suspension setup under 1grand? (Sinitron)
Yeah, if you making suspension mods based on looks. go with springs, and be done. If you are looking for looks and performance, go coilovers. If you are running GStock and want to close the gap.......go with Koni yellow.
Old Jul 29, 2001 | 09:30 AM
randomwalk101's Avatar
well if i had read this earlier, then i'd probably would have sold u my Koni yellows and springs for $400 w/ shock cap, rubber mounting, front folks and everything..but i have a guy line up already..oh well..
Old Jul 29, 2001 | 10:23 AM
Ibuprofen's Avatar
Default Re: suspension setup under 1grand? (randomwalk101)
how bout i give you 401 bUx for your suspension?
DjBij099
Suspension & Brakes
20
Oct 16, 2009 08:38 PM
FTW
Honda Civic (2006 - 2015)
Apr 24, 2008 11:57 PM
DIRTYsouthBB6
Oct 10, 2007 05:06 AM
bibong
20
Dec 3, 2006 09:35 PM
DC2Monster
Mar 9, 2003 06:01 PM
