new cams... now car boggs ???
Old Jul 2, 2003 | 05:29 PM
1hotintegra's Avatar
Default new cams... now car boggs ???
i just put in skunk2 stage1 cams in my car... i have a completly stock exhaust system...header, cat, exhaust... all stock.. when i hit vtec it boggs a lil bit and then again when the secondaries open... the ecu is compltly stock right now.. and it is not tuned... im goin to get it tuned and everything i was just wondering if this was normal..
timing is also set at stock
Old Jul 2, 2003 | 07:32 PM
tinkerbell's Avatar
Default Re: new cams... now car boggs ??? (1hotintegra)
did you adjust the valve clearances?
Old Jul 2, 2003 | 07:43 PM
B00ST2nR's Avatar
Default Re: new cams... now car boggs ??? (tinkerbell)
Car is probly bogging because it's not tuned. Get some adjustable Cam gears, a fuel tuning device (VAFC or Hondata), and tune it. With stock everything, and untuned, there most likely will be a huge dip in power at the Vtec engaging point. Tuning is very important...
However, I would get I/H/E and some other stuff before tuning it, since tuning cost a good amount of $$$. To tell you the truth, you should've gotten the Cams after you had everything set up.
Old Jul 2, 2003 | 07:46 PM
powerfulperformance's Avatar
Default Re: new cams... now car boggs ??? (Skunk2nR)
Yeah your car needs tuning. If you have a vtec controller or something try changing to vtec activation point..
Old Jul 2, 2003 | 07:50 PM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tinkerbell &raquo;</TD></TR><TR><TD CLASS="quote">did you adjust the valve clearances?</TD></TR></TABLE>
are they??
Old Jul 2, 2003 | 09:54 PM
Default Re: new cams... now car boggs ??? (francisco flores)
yea
johnny_bighood
11
Apr 29, 2009 10:14 AM
VTECcnIT
Dec 15, 2005 01:26 PM
gogou99
14
May 22, 2004 10:40 AM
1hotintegra
Jul 3, 2003 01:38 AM
brownman72000
Sep 13, 2002 01:59 PM
