wheel spacers?
when should you consider using them. i have the speedmaster 15x6.5's (40mm offset) on my 96 hatch. when i turn the wheel almost to full lock, and put a lot of load on the suspension, i scrape the tire on the inside front of the frame......i never had this problem with a 38mm offset wheel.
can you run a 2mm wheel spacer without upgrading to longer wheel studs? what is the general rule on how much thread engagement is mandatory for safety?
BTW, i just put on some Azenis. i know they will be worse than my pirelli p700's have been. thanks.
I have yet to see any 2mm spacers... about the smallest I have seen is 3mm.
If you are interested I have an extra set that I have no need for. Hit me up on email or PM if you are interested.
Nash
a71rambler@hotmail.com
Nash
CivicSIRacer....does that mean 99+ si? anyways, would i then have problems with rubbing on the fender if i use as much as a 3mm spacer? what wheel tire combo are you running?
hey ford......5mm spacers on 99 si hubs, 92 cx hubs.....no rubbing .....probably 4-5 turns on the studs with the nuts with antiseize.....NO PROBLEMS!!! i just rolled my front fenders....
steebypue
Apr 20, 2003 08:53 PM
