Car won't start??? The car ignites but won't turn over.
Old Jul 2, 2003 | 01:11 PM
Audio28's Avatar
Default Car won't start??? The car ignites but won't turn over.
Alright, my ex-girlfriend's car won't start. When I turn the key, it sounds like it's going to turn on, but when I stop turning the key, the car just shuts off. I'm thinking it's the distrubutor. What can I do to check it. What else do you think could be wrong w/ it? Thanks
Old Jul 2, 2003 | 01:22 PM
Chris y0!'s Avatar
Default Re: Car won't start??? The car ignites but won't turn over. (Audio28)
could be fuel as well
Old Jul 2, 2003 | 01:42 PM
Audio28's Avatar
Default Re: Car won't start??? The car ignites but won't turn over. (Chris y0!)
There's plenty of fuel. My fiend turned on the car, while he was doing so, I opened one of the spark wires. I didn't see any spark coming from the sparkplugs. What could be wrong. The car sounds like it's gonna turn over, but it won't stay on. I tried to gas the car while i turned the ignition but still no luck. Please help.
Old Jul 2, 2003 | 01:44 PM
Chris y0!'s Avatar
borrow a distributer from a friend's car and see if it works.
Old Jul 2, 2003 | 02:58 PM
B16b2b's Avatar
is it trying to crank at all? maybe starter problems?
Old Jul 2, 2003 | 04:06 PM
transmission11's Avatar
get a voltmeter and check the battery, then try to crank it over and have someone check the to see what the volts jump up too. if its real low like 3-4v. before and during the crank over you need to replace the battery and hopefully that should solve your problem, similar situation happend to me
Old Jul 3, 2003 | 01:54 AM
anthony campos's Avatar
If you didn"t get any sparks from the distrubutor while trying to strar its your distrubutor.
Old Jul 3, 2003 | 03:49 PM
Audio28's Avatar
Default Re: Car won't start??? The car ignites but won't turn over. (anthony campos)
i got new spark plugs, and the car still didn't start. I'm gonna get my friend's distributor, and see if that works. Any other ideas?
Old Jul 3, 2003 | 05:33 PM
strngwys's Avatar
check your ignitor with a meter i had the same problem and the ignitor was dead
good luck
90efsedan
Feb 22, 2010 12:04 PM
zacatkings
27
Mar 22, 2006 05:26 AM
4runner
10
Jun 20, 2005 08:40 PM
CivicHP
Jun 1, 2005 02:27 PM
DCtwoR
Jun 20, 2002 07:10 PM
