Rear Disc Conversion parts?...Master Cylinder...
Old Jul 2, 2003 | 11:32 AM
AGS's Avatar
AGS
Default Rear Disc Conversion parts?...Master Cylinder...
I am doing an Si rear dics conversion on my 99 DX Hatch and i was wondering if i really need the Si Master Cylinder? Or a proportioning valve or is that only for ABS cars? Thanks for the help.
Old Jul 2, 2003 | 01:44 PM
sleeprhatch's Avatar
Default Re: Rear Disc Conversion parts?...Master Cylinder... (japcruzer)
yes you need the master cylinder but the prop valve is the same. I had my friend at the Honda dealer look up part #'s on them and they are the same.
Old Jul 2, 2003 | 02:22 PM
NonovUrbizniz's Avatar
Loved
Default Re: Rear Disc Conversion parts?...Master Cylinder... (sleeprhatch)
If it has stock rear drums they are NOT the same...
drum has a 30/30 and disk has 40/40 or 41/41 something like that...
It will work with either but it will only work correctly with the disk proportioning valve...
Old Jul 2, 2003 | 05:11 PM
AGS's Avatar
AGS
Default Re: Rear Disc Conversion parts?...Master Cylinder... (NonovUrbizniz)
OK thanks for the info.
Old Jul 2, 2003 | 11:48 PM
salbaje's Avatar
You can do the swap without changing your booster and master cylinder. But you wont get the proper feel of the braking power.
Soichiro_Fan04
22
Jul 14, 2009 02:27 PM
Bryro22
Aug 23, 2005 02:07 PM
aznphantoms
Dec 2, 2004 11:43 PM
goldenk10
Jul 19, 2004 12:54 PM
