Stupid fuel filter question.
Paragraph Alert
I unhooked my top fuel line to the fuel filter trying to get a little gas into a jar to check for water (bad gas). Anyway when I screwed it back in it leaks now when the car is running. Thankfully I caught it quickly. I'm guessing the leak is because they are crush washers and can only be used once?
Very true. Crush washers are designed to be single use items. You can reuse them on the oil pan drain bolt if you want to (I always change mine), but where as the fuel lines see more pressure you got leaks.
You might want to check and make sure everything is tight too.
Good luck
Good luck
Steezn4NOReason
13
Jul 19, 2005 12:45 PM
all420
Mar 5, 2003 10:17 AM
