Parting Out: B20Vtec; '00 B16a2; Lots of misc and Civic Parts too
Old Jul 2, 2003 | 08:15 AM
Simple's Avatar
Default Parting Out: B20Vtec; '00 B16a2; Lots of misc and Civic Parts too
Im going to Turbo my new motor, so there will be a list of parts I'm trading for at the bottom. Anyways....
B20B4 Block
block # JHD1840VC057705
Complete from oil pan to head gasket, minus flywheel, clutch and pressure plate
USDM B20B4 block, about 15k
JE 11.5:1 pistons, used for about 8k
Propper Vtec oil/water pump, with belt if you want
Already T'd off and external oil line ran.
Also, forgot to mention before, its got a Blueprinted and Balanced bottom end
When I blew a head gasket at the track, i went home and took off my B16 head (thats also for sale later on in post) to replace the gasket, I bought a *brand new* gasket (included) to replace it with. I put the head back on and started to torque down the bolts, and some (3) wouldn't Torque. so... the block threads (i suggest all) need to be re-tapped.
Asking 650 with Pistons included.
B16a VTEC head
Its a first gen head. Pretty sure its a '90.
Complete head, with a second gen ('00) Intake manifold with all sensors, injectors, fuel rail... everything. Still has 1st gen Throttle Body.
READY FOR LS/VTEC or B20Vtec
the head has been plugged for ls/vtec, and has the external oil line fitting in already, and dowel holes have been drilled.
This is ready to bolt-on to an LS or B20 Block that has been T'd for oil.
asking 650
Now for loads of my other crap:
2000 Si Alternator $60
2000 Si Oil pump (20k) $60
2000 Si Axles (20k) Driver's side $50 Pass side $old
2000 Si half shaft (20k) $50 (Pending)
2000 Si ECU $70
2000 Si wiring harness, complete from engine bay to ECU $100
2000 Si Flywheel (20k) never been resurfaced $65
2000 Si Clutch (20k) $60
2000 Si Pressure plate (20k) $60
2000 Si or B series Mounts All for $80, or will peice out.
2000 Si Header, with o2 still attched (20k) $45
B-series Vtec Head bolts, (B16 i think) $60
B-series MAP sensor $15
92-95 Civic stock springs $50
92-95 optional CD player $70
92-95 Civic Hood (white) $60
92-95 Power steering rack $60
92-95 Cruise control Brain $5
92-95 Passenger side Clear corner $5
92-95 stock lower airbox $10
92-95 stock Jack $10
90-93 Integra LS Cams, with one cam gear $20
88-91 Civic Mud Gaurds $10
Misc Clips/hoses/spark plug holders/rad. hoses
Stock GO-PED TB, exhaust, intake, skid plate, flywheel, rims, and some other stuff
And a Ported Go-Ped Cylindar head.
Here is the ECU and the Headbolts
LS cams and Civic Springs
2000 Si oil pump, resitor boxes, and MAP sensor
Go-Ped parts
Honda Optional CD player
Mounts
2000 Si header
2000 Si axles and half shaft
AC, Power steering pump, and another shot of the half shaft
2000 Si Clutch, Pressure plate, and flywheel (20k)
More pictures to come, but it takes me half an hour to load 3
2000 Si AC condensor (20k) $old
2000 Si power steering pump (20k) $old
2000 Si Passenger side Axle (20k) $old
3 Resistor Boxes $old
ok, there it is.... i will trade for turbo parts and things listed below.
ITR/Skunk2 Intake manifold
t3/t04 turbo
hondata IM gasket
Intercooler
Tial Wastegate
BOV
Hondata S200
GSR cams
Black Armrest for EG
Walbro 255lph fuel pump
12:1 FMU
DSM 450cc injectors
Apexi Vafc
Turbo Timer
Gauges (autometer)
CF spoon lip
and any other turbo parts you might have.
Modified by Simple at 9:41 PM 7/6/2003
Old Jul 2, 2003 | 06:44 PM
Simple's Avatar
Default Re: Parting Out: B20Vtec; '00 B16a2; Lots of misc and Civic Parts too (Simple)
bump
Old Jul 2, 2003 | 09:23 PM
jwlmike's Avatar
interested in the pass axle and the ps pump.
Old Jul 3, 2003 | 07:37 AM
Simple's Avatar
Default Re: (kazejin)
you've got IM.
bump
Old Jul 3, 2003 | 06:04 PM
Simple's Avatar
Default Re: (Simple)
bump... loading more pictures
Old Jul 3, 2003 | 06:44 PM
88civicHB703's Avatar
trade yah my pc for that b16a head
Old Jul 3, 2003 | 06:51 PM
Simple's Avatar
Default Re: (88civicHB703)
haha, my brother is trying to do the same thing.... good offer tho
Old Jul 3, 2003 | 09:25 PM
Simple's Avatar
night time bump
Old Jul 3, 2003 | 10:20 PM
b16powwer's Avatar
i got a b16 skunk2 intake manifold, still like new, how much would you want cash over for the b20 block, and i am in chicago il. let me know. email me at faraj77@aol.com thanks
Old Jul 3, 2003 | 11:33 PM
jumpmann23's Avatar
From: Your really lame if you dock my points, WA, 98033
Default Re: Parting Out: B20Vtec; '00 B16a2; Lots of misc and Civic Parts too (b16powwer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">B-series Vtec Head bolts, (B16 i think) $60
might be the reason why you blew your headgasket? anyway thats a good price on the b20 block if you where local i would pick it up.
Old Jul 3, 2003 | 11:43 PM
djay86's Avatar
Default Re: Parting Out: B20Vtec; '00 B16a2; Lots of misc and Civic Parts too (ek9folife)
you got any other goped stuff? i might be interested.
Old Jul 4, 2003 | 07:58 AM
Simple's Avatar
Default Re: Parting Out: B20Vtec; '00 B16a2; Lots of misc and Civic Parts too (djay86)
go-ped part thread: https://honda-tech.com/zerothread?id=553256
on the skunk2 manifold. I'm trying to work a deal with someone local on my B20Vtec setup for his LS/Vtec setup plus cash. BUT, if it fell threw... the skunk2 mani plus $500
Old Jul 4, 2003 | 01:39 PM
jwlmike's Avatar
pass axle, ps pump, and ac comp SOLD to me!
Old Jul 4, 2003 | 02:07 PM
Simple's Avatar
all pictures are up now
Old Jul 4, 2003 | 06:37 PM
Simple's Avatar
ttt please
Old Jul 5, 2003 | 03:31 PM
Simple's Avatar
bump for some stuff that i know someone needs/wants
Old Jul 6, 2003 | 10:07 AM
Simple's Avatar
bump
Old Jul 6, 2003 | 05:39 PM
Simple's Avatar
bump, agian
Old Jul 6, 2003 | 06:27 PM
BlueTeg's Avatar
You've got IM. If you're close enough I can do a pick up deal (my roommate's bro lives in NE Oregon)
Old Jul 6, 2003 | 06:53 PM
Simple's Avatar
Default Re: (BlueTeg)
IM'd you back
Old Jul 7, 2003 | 08:31 AM
Simple's Avatar
ttt
Old Jul 8, 2003 | 10:18 AM
Simple's Avatar
ttt, also have a 4 wire 02 sensor
Old Jul 8, 2003 | 11:17 AM
avividmemory's Avatar
PM'ed you about the block!
Old Jul 10, 2003 | 12:32 AM
Simple's Avatar
ttt, block and head are pending
Old Jul 11, 2003 | 01:47 PM
Simple's Avatar
bump
