slave cylinder, clutch problems..help!
Guest
Posts: n/a
i have a 94 LS and the slave cyl went out so i replaced it and bleed it about 15 times, it worked fine i drove it for 1 day and it started sticking and eventually went to the floor...so i bleed it agin about 10 times and the pedal was fine for about 1 hour...am i bleeding this enough? i cant see any leaks from the master or slave cyl...mabye i got a bad one.?? anyone?
How are you bleeding it? Sometimes no matter how many times you do it by hand, it just doesn't work.
Get yourself a power bleeder, that'll work every time. Otherwise, you'll constantly get those air bubbles that render your clutch useless.
