How to remove rear bumper support on a 1992 Integra?
Old Jul 1, 2003 | 05:40 PM
crooked muffler's Avatar
Default How to remove rear bumper support on a 1992 Integra?
how much does it weigh?
Old Jul 8, 2003 | 08:03 PM
Default Re: How to remove rear bumper support on a 1992 Integra? (anti-ricecake)
anyone?
Old Jul 9, 2003 | 05:51 AM
crack head's Avatar
I don't know how much it weighs. But here is how to take it off........ 91 shouldn't be different than a 92.......
Remove the screwa that hold the rear mud flaps on. (3 total)
Remove the two screws on each side of the bumper cover in the wheel wells.
Remove the panel at the rear of the hatch.
Get under the car and remove the plasic covers that cover the lower nuts tht hold the bumper support on. One us just above the tail pipe and the other is in the same location on the passangers side. The covers are held on by 2 plastic phillips head screw clips. Then remove the 2 nuts (1 on each side)
While you are under the car disconnect the license plate lights the wires come out on the passangers side. there are 2 wires with bullet type connectors.
Go inside the hatch and remove the 2 nuts just above the floor / unibody frame ( they look just like the ones that were removed under the car) Ther is 1 on each side.
have someone help you, one person on each side. Put one hand on the wheel well and the other on the rear part of the bumper. Pull out on the wheel well and push twords the rear of the car. The bumper cover and support should come free.
Oh... And getting the rusted bolts that hold the bumper to the support are a pain in the butt sometimes.......
Old Jul 9, 2003 | 07:18 AM
rastropovitch
Guest
Posts: n/a
Default Re: How to remove rear bumper support on a 1992 Integra? (crack head)
The 90-91's are slightly differnt than the 92-93's... in the bumper cover and the support. the 90-91's mounting bracket has a different bolt pattern. I beleive you can use either one on either car, but you will need the mounting bracket for the specific support that you are using. You take it off by removing the two screws inthe fender well on both sides of the front of the car, the remove the bumper lens' and unbolt the two bolts on each side that you can see through the lite hole. it will lift right off
Schu
noobaccord
Apr 27, 2010 08:05 PM
GoldCoin
Mar 27, 2007 10:31 PM
martik
Mar 8, 2004 06:46 PM
rasta420
Jan 18, 2003 07:55 AM
R1020
Sep 14, 2001 03:21 PM
