Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
HPDE Rules on Fuel Cells
Old Jul 1, 2003 | 04:20 PM
len's Avatar
len
Default HPDE Rules on Fuel Cells
Where can I find rules on this pertaining to any High Performance Driving Events and Fuel Cell usage?
I don't want to install it someplace to find out that it's illegal to have it installed there. I do not plan to track my car often, more so at the drag strip, and I already know the rules at the dragstrip.
Thanks for any information in advance.
Len
Old Jul 1, 2003 | 06:27 PM
Mike P.'s Avatar
25 Year Member
Default Re: HPDE Rules on Fuel Cells (len)
I can't say for sure that I've ever seen anything concerning fuel cells on the technical inspection forms I've completed in the last few years for HPDE-style events.
But the fact that I've seen full-blown racecars equipped with these fuel-cells participating in the same event tells me that they were OK for those events. Better check with the organizers to be sure.
PS-is there a different type of fuel cell used for drag-racing than there is for road-race applications?
Old Jul 1, 2003 | 06:57 PM
Mohudsolo's Avatar
Default Re: HPDE Rules on Fuel Cells (Mike P.)
I think most schools will defer to the SCCA rulebook when it comes down to it. Basically rules are, not mounted in driver's compartment, specified minimum distance from ground- 6" unless within the bodywork and stock floorpan, metal between cell and driver. Vents to the outside of the car and a check valve so it won't overflow if the car is upsidedown.
Old Jul 1, 2003 | 07:59 PM
.RJ's Avatar
.RJ
Default Re: HPDE Rules on Fuel Cells (Mohudsolo)
I'd defer to the GCR (or nasa's CCR) regarding it as well, just in the name of safety.
Old Jul 1, 2003 | 08:14 PM
getfast's Avatar
Default Re: HPDE Rules on Fuel Cells (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">I'd defer to the GCR (or nasa's CCR) regarding it as well, just in the name of safety.</TD></TR></TABLE>
A fuel cell in an HPDE car should defer to amateur roadracing rules, not unlike bar/cage/harness/window net/kill switch/etc... "if it's in there, it's gotta be SCCA and/or NASA legal."
IMHO from an occasional tech inspector,
Jon
Old Jul 1, 2003 | 08:18 PM
Warren's Avatar
Wrong-Way Wang
A fuel cell for road racing has to be properly protected, and seperated from the driver's compartment by a metal bulkhead (meaning it's boxed).
I don't understand why you would want a fuel cell for drag unless it's a dedicated drag car in a pro class, running a TINY fuel cell. A cell small enough for that will hardly get you around one lap of a track.
At any rate, here are the NASA rules. Keep in mind that the rules for a fuel cell are created with the mindset that the car is properly caged.
http://www.nasaproracing.com/r...R.pdf
Warren
tony1
Apr 23, 2009 11:53 AM
rotten
Apr 2, 2004 12:46 PM
badCRX
Mar 30, 2004 01:54 PM
Bnjmn
Feb 6, 2004 07:41 AM
RRRex
12
Mar 31, 2003 08:55 PM
