Help replaced the bolts that go up to spark plug!!!!
Old Jul 1, 2003 | 03:36 PM
stryderlis's Avatar
Default Help replaced the bolts that go up to spark plug!!!!
Well, I had to replace those bolts because I broke mines. Now when I move in reverse or forward, it squeeks. But if I stay in one spot and just rev, no noise. I didn't know the torque specs so I just twist it a quater of turn. Do you think those screws are capable of make my car make those noises?
Old Jul 1, 2003 | 03:41 PM
Patrick's Avatar
Default Re: Help replaced the bolts that go up to spark plug!!!! (stryderlis)
I sounds like something with your tranny, maybe throwout bearing? Go to Autozone and get one of those cheap $14 manuals and do it right, if it still does it you have your answer.
Old Jul 1, 2003 | 03:48 PM
g5r's Avatar
g5r
Default Re: Help replaced the bolts that go up to spark plug!!!! (gsr_vx_wOOt!)
man that is funny cus i just broke mines yesterday. them bolts are not cheap.
yea it might be your tranny.
Old Jul 1, 2003 | 04:38 PM
stryderlis's Avatar
Default Re: Help replaced the bolts that go up to spark plug!!!! (g5r)
Well I don't think its the tranny. I turned the car off and put it in neutral and when I push it back and forth it still makes that noise. Do you think that tightening those nuts too much might restrict something from work and causing the squeaking.
Old Jul 1, 2003 | 04:53 PM
KOALA YUMMIES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr_vx_wOOt! &raquo;</TD></TR><TR><TD CLASS="quote">I sounds like something with your tranny, maybe throwout bearing? Go to Autozone and get one of those cheap $14 manuals and do it right, if it still does it you have your answer.</TD></TR></TABLE>
Side question: whats a throwout bearing?
Old Jul 1, 2003 | 05:10 PM
hybridreams's Avatar
Have you even checked to hear where the squeak is coming from?
And if your engine is off and that noise is still being made by just rolling your car around in neutral, then that can't be it.
Old Jul 1, 2003 | 05:57 PM
EVIL Hx Coupe's Avatar
Default Re: Help replaced the bolts that go up to spark plug!!!! (hybridreams)
If it does it when the car is off it cant be that.... It could something in your tranny...
Old Jul 1, 2003 | 06:05 PM
stryderlis's Avatar
Somewhere under the engine. Not sure where though. In the middle under the engine because when I push it I can hear the noise from both sides of the car.
Old Jul 1, 2003 | 06:27 PM
Shawn C's Avatar
In The Garage
sounds like your motor mounts squeaking to me. did you just clean your engine or anything? listen to the driver's side mount when you move the car. either that or some ball joint in the front suspension.
side note- the throwout bearing is what the clutch pressure plate rides on when it is disengaged.
Old Jul 1, 2003 | 07:30 PM
BoostedSi's Avatar
Default Re: (22lbGS-R)
maybe its your brakes, my rear brakes used to sqeak every once in a while when i was reversing
Old Jul 2, 2003 | 04:07 AM
stryderlis's Avatar
Nope, I didn't clean my engine recently. I didn't do nothing recently. The only thing that I have done was put those screws in. Does anyone know what those screws connect to on the bottom?
Old Jul 2, 2003 | 04:10 AM
wHOAlly's Avatar
Default Re: (stryderlis)
those bolts are 20ft/lbs, and the smaller ones are 8ft/lbs
Old Jul 2, 2003 | 04:15 AM
igo4bmx's Avatar
wow... i just had a problem with my car the past two days with it rattling like crazy sometimes... only happened when driving forward, and not reverse... i just floor my car this morning till 7 psi and then it went away :dunno:
Old Jul 2, 2003 | 04:48 AM
lonefuzzy79's Avatar
Default Re: (igo4bmx)
That appears to be your cam lash, you might wanna get a manual and find out what the torque specs are cause those are kinda important. It could be that just revving is not putting your motor under load but moving the car is putting enough stress on the cams to make them slop around? Or check your wheel bearings and CV joints. Maybe those are squeeking? Wheel clearance maybe rubbing a tire? just my.02
One other thing do not use that air-ratchet on your motor, that's just dumb and a good way to strip/break your bolts.
Old Jul 2, 2003 | 06:49 AM
stryderlis's Avatar
Default Re: (lonefuzzy79)
Well, everything is fine now. I just loosen the screws up and tighten it but not so much and now the sqeeking is gone. I didn't know those screws made such trouble. Oh and Lonefuzzy79 that's not my had in the picture. Its just a picture from cspeed.com that I found.
Old Jul 2, 2003 | 08:17 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I don't know what you did, but if there was a squeeking sound while the engine was off, it was definitely not those bolts that hold the valve cover, no way no how. They screw into the engine head.
Old Jul 2, 2003 | 08:27 AM
ZEAL-SPORTS's Avatar
LOL!! WTF!!, ANYWAYS I REMEMBER THAT I BRAKE ONE OF THE VALVE-COVER BOLTS A LONG *** TIME AGO, BUT LUCKLEY I HAD A FRIEND AT HONDA AND HE HOOKED ME UP WITH A NEW ONE FOR FREE. THOSE BOLTS SHOULD BE PUT ON WITH A RACHET AND SHOULD ONLY BE SNUG, OR FINGER TIGHT.
;{O = CHINESE MAN!!
Old Jul 2, 2003 | 09:25 AM
stryderlis's Avatar
Default Re: (ZEAL-SPORTS)
Those bolts cost me like 6 bucks a piece. And I think you have to do more then hand tighten it because it was kinda hard to take off when I had to replace them.
Old Jul 2, 2003 | 01:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZEAL-SPORTS &raquo;</TD></TR><TR><TD CLASS="quote">Side question: whats a throwout bearing?
;{O = CHINESE MAN!!</TD></TR></TABLE>
You're an idiot, congradulations. Why was my question funny? The second person to post mentioned that it could be the throwout bearing, so I asked what it was. So shut the **** up you idiot, and stop making fun of Chinese people.
Old Jul 2, 2003 | 01:58 PM
racecarpete's Avatar
Default Re: (KOALA YUMMIES)
if your car squeaked when it was off it is your engine mounts. Mine squeak, no big deal.
igorka_91
Sep 30, 2009 12:16 PM
TravisCadello
Nov 26, 2008 07:13 PM
trav143
13
Oct 5, 2008 08:08 PM
rasinhell
Jan 30, 2005 02:34 PM
turbosi03
Oct 22, 2004 06:17 PM
