motor swap
Old Jul 1, 2003 | 01:42 PM
drive4aliving's Avatar
Modified by drive4aliving at 11:58 PM 1/23/2007
Old Jul 1, 2003 | 01:47 PM
Dave-ROR's Avatar
Default Re: motor swap (drive4living)
displacement owns. If you have a running B18C5 in your DC2R already I wouldn't bother with the B20 though.. just build the B18C5.. if your B18 is dead then get the B20 and use the ITR head.
Old Jul 1, 2003 | 01:51 PM
RTW DC2R's Avatar
what is the purpose of your car going to be? Id say a general consensus would be the B20/vtec would have better torque/low end numbers and be good for b00st. The B18C5 would be good for all motor high compression and revving the **** out of it. Thats probably the typical answer you will get but there are people that have done the opposite successfully. There are too many factors to say which is better or not.
Old Jul 1, 2003 | 04:08 PM
00MRSi's Avatar
Default Re: (drive4living)
After reading your sig, just have "mommy" or "daddy" buy you a Hype R..
Most importantly, do some research and think about the intended use of the car..
GoLowDrew
Jun 12, 2013 01:46 PM
beantowncoupe98
15
Apr 30, 2011 04:28 PM
roger93si
Jan 26, 2007 08:51 AM
b20egX
May 26, 2006 02:59 AM
gATOr65
Aug 12, 2004 06:49 PM
