Quick question on Clutches: B16 and B18C5 bolt pattern difference
Im pretty sure the B16 clutch has 9 bolts and the B18C5 has 6 bolts. I know its been discussed somewhere before, but couldnt find the answer. Can anyone confirm this? I think my pressure plate is shot and my buddy has a new B16 clutch plate and Id like to snag it from him if it will work before he sells it.
some PP/flywheels can accept 9 bolts, some can't. I know Toda/Spoon can use 9 bolts and the exedy flywheels have 9 bolt holes. You could still just use 6 though.
so the R clutch plate has 6 bolts and the B16 has 9 correct? Ive got the CM flywheel so as long as the PP has 6 bolts Im assuming it will line up properly.
funny you asked, i pulled my cm flywheel off of my jdm b16a and put it on jdm b18c and never even counted..........straight across swap (91 b16a to 98 b18c)
crxgurlllll
11
Dec 10, 2002 09:23 AM
