1/4 Mile ET time ????HELP
Old Jul 27, 2001 | 11:18 AM
JDM R98's Avatar
Default 1/4 Mile ET time ????HELP
Hi..The track that i am running at his a elevation of 665FT..I am wondering what is my corrected time if i hitted a 14.2@99mph at the high elevation track..thanks
Old Jul 27, 2001 | 11:20 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: 1/4 Mile ET time ????HELP (JDMR98)
hitted?
Old Jul 27, 2001 | 11:42 AM
TypeR0207's Avatar
Default Re: 1/4 Mile ET time ????HELP (Ross1013)
If you run a search on google.com, you'll find some site that has it, but since it is only 600+ ft, maybe drop a tenth or so to get an idea of corrected? It wouldn't be much different.
Old Jul 27, 2001 | 12:12 PM
typer694's Avatar
New User
Default Re: 1/4 Mile ET time ????HELP (TypeR0207)
Lol! You think that is high? Try running your car here in NM. The elevation at one of the drag strips where i run my car is over 4,000 feet above sea level, and another is over 6,000 feet above sea level. My best 1/4 mile time to date is a 14.8, probably would be quite a bit faster at a lower elevation, i don't think that 665 feet above sea level is hurting your 1/4 mile times at all.
[Modified by typer694, 1:15 PM 7/27/2001]
Old Jul 27, 2001 | 12:20 PM
H23 Power's Avatar
Default Re: 1/4 Mile ET time ????HELP (typer694)
probably slightly less than a 10th of a second
Old Jul 27, 2001 | 12:47 PM
01ITR#700's Avatar
Default Re: 1/4 Mile ET time ????HELP (01GSR)
01GSR is probably right, maybe, just maybe 1/10th of a second difference.
I have an altitude chart, and it only goes down to 1200ft. above sea level. Bandimere Speedway here in Colorado is well over 5,000ft. above sea level I believe, it sucks Depending on your Trap speeds we're about a second slower here than sea level
HTH
M
Old Jul 27, 2001 | 12:49 PM
TxR's Avatar
TxR
New User
01GSR, Do you run at River City Raceway? If so what times do you see other stock R's run there?I went there about a month ago and my best 1/4 time was 15.12sec. Yes it could be my driving, but I don't think sio I tried everything, feathering the clutch, dropping it at different RPMs, but that was still my best time. I think I was hooking up pretty well. I didn't pull anything out of my car (spare) and I had just over half a tank of fuel.
Anyone, could it be the heat here, or the weight of the fuel, or did I just get one of the weaker R's...?
Old Jul 27, 2001 | 12:51 PM
TxR's Avatar
TxR
New User
Default Re: 1/4 Mile ET time ????HELP (AustinR)
Where does San Antonio fall on that altitude chart, 01ITR#700?
Old Jul 27, 2001 | 01:05 PM
01ITR#700's Avatar
Here ya go: http://gntype.org/techarea/misc/altitude.html
Your going to have to get the altitude of the track...
Hopefully that link works, it tells you how to read the chart and do the math.
HTH
M
Now you can see why our times kinda suck out here
Old Jul 27, 2001 | 01:34 PM
Wildohiorice's Avatar
New User
Default Re: 1/4 Mile ET time ????HELP (01ITR#700)
Your link doesn;t work lol or is it just me
Old Jul 27, 2001 | 11:26 PM
01ITR#700's Avatar
Default Re: 1/4 Mile ET time ????HELP (Wildohiorice)
Whoops, sorry about that, I missed a few letters I was on my way out the door when I put the link in initially http://www.gnttype.org/techarea/misc/altitude.html
Old Jul 27, 2001 | 11:33 PM
jonnyR's Avatar
Hey typer694........a 14.8 is AWESOME for your elevation!!!!!!!
That translates to about a 13.8 !!
DAYM! Is that stock?
Old Jul 29, 2001 | 09:16 PM
typer694's Avatar
New User
Default Re: 1/4 Mile ET time ????HELP (jonnyR)
jonnyR
Car has a few bolt ons, nothing internal yet, just your basic mods, and a set of drag radials are used when i go to the drag strip. The car felt really strong from the factory though.
[Modified by typer694, 10:18 PM 7/29/2001]
Old Jul 29, 2001 | 10:41 PM
Ochux's Avatar
New User
AustinR a buddy of mine in his 01 ran a 14.8 bone stock at RCR! Did you go to the Import shootout Friday the 27th...
Old Jul 30, 2001 | 07:08 AM
jg's Avatar
jg
not sure if this is correct, but, I heard that most dragstrips are equipped with timing equipment that compensates for temperature, humidity, and altitude. I this true? Anyone else heard this?
jg
Old Jul 30, 2001 | 08:06 PM
typer694's Avatar
New User
Default Re: 1/4 Mile ET time ????HELP (jg)
Not true.
Machine1
Jan 17, 2005 01:00 PM
el arbi
Apr 29, 2003 07:19 AM
integranator
Nov 21, 2002 10:06 AM
chillly
Nov 4, 2002 11:42 AM
itr1244
Sep 13, 2002 09:51 AM
