Whats the best fitting spark plug wires for my 94 gsr?
Old Jul 27, 2001 | 09:30 AM
supadupamikey's Avatar
Default Whats the best fitting spark plug wires for my 94 gsr?
I'm looking to replace my stock plug wires, I need to adjust my valves, and replace my cam seals, and I'm going to repaint my valve cover (coating is flaking off) and I figure I might as well change the plug wires while I'm at it.
Whats the best fitting plug wires for my teg? I know I've used Accel and NGK wires in the past, the NGK wires I had on my probe gt and they were fine, however, the Accel wires I put on my Talon tsi awd didn't fit as good as the stock wires did. They were way too long, or too short and they didn't fit securely in the plug wells either.
I dont want to make that mistake again.
Also, I'm looking for a reasonably priced set of wires too... I seen the magnecores on groupbuy for like $70, which is fine. However, I'm not looking to spend a whole lot more than that, I could care less if Spoon, or Mugen, or any of those other crackhead companies have a set for $6000 or whatever. A wire is a wire, it carries a spark.
Old Jul 27, 2001 | 09:43 AM
acuraintegraman's Avatar
Default Re: Whats the best fitting spark plug wires for my 94 gsr? (lilmikey77)
msd....i have a set of magnecors and i don't have the fitting problems as much as other people, but there are times where it does get loose. msd is what i'm trying next and are what people recommend
Old Jul 27, 2001 | 10:47 AM
bigTom's Avatar
Default Re: Whats the best fitting spark plug wires for my 94 gsr? (acuraintegraman)
leave them stock... u really dont need wires
Old Jul 27, 2001 | 11:04 AM
Default Re: Whats the best fitting spark plug wires for my 94 gsr? (ek9t)
plug wires dont last forever, and since i gotta tear into everything, i'd rather do it all at once
ps. they already have 120k miles on them
Old Jul 27, 2001 | 12:33 PM
Ubermensch's Avatar
replace with new stock, NGK
Old Jul 27, 2001 | 01:15 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Whats the best fitting spark plug wires for my 94 gsr? (Ubermensch)
NGK by far
Old Jul 27, 2001 | 01:51 PM
H23 Power's Avatar
Default Re: Whats the best fitting spark plug wires for my 94 gsr? (B18C-EJ1)
yeah, get the NGK blue ones...very nice looking...perfect fit...and about $40 for a set
[Modified by 01GSR, 10:52 PM 7/27/2001]
Old Jul 27, 2001 | 01:53 PM
Default Re: Whats the best fitting spark plug wires for my 94 gsr? (01GSR)
Do NGK wires come in any other color besides blue? My teg is red, and everything on it is black or red.
Old Jul 27, 2001 | 02:01 PM
redline's Avatar
MSD are nice!
Old Jul 27, 2001 | 03:51 PM
Max GSR's Avatar
I had the same problem with the Accel's not fitting very well, although they seem to work just fine, and are well made. I've tried the Moroso's and those were the biggest pieces of crap! They all broke the first time I had to remove them to get at my plugs!!! I'm putting on my new MSD's this weekend. These are BY FAR the nicest wires I've ever seen!
Old Jul 27, 2001 | 06:09 PM
keys's Avatar
Default Re: Whats the best fitting spark plug wires for my 94 gsr? (Max GSR)
i don't think wires really have much of a difference besides color so anyone should be fine...... btw, i have magnacor wires and they work great, just like NGKs
Old Jul 27, 2001 | 08:26 PM
ALF's Avatar
ALF
Default Re: Whats the best fitting spark plug wires for my 94 gsr? (keys)
I have MSDs. They don't fit as well as I thought they would. For some reason, my #2 wire plug is longer than the rest. WTF!? It still works though. The wires are noticeably harder to plug in than stock, but what would you expect from a non-OEM part? But once you get them on, they go on nicely. It's a pretty tight fit. Looks really nice too.
[Modified by Dozed, 12:28 AM 7/28/2001]
Old Jul 27, 2001 | 08:33 PM
quikrpm'z's Avatar
Default Re: Whats the best fitting spark plug wires for my 94 gsr? (Dozed)
1) stock wires
2) ngk's
Old Jul 27, 2001 | 11:17 PM
Rory Breaker's Avatar
There are differences between wires...Nologys for example are the only wires with built-in capacitors.
If I were you I would go with NGK's...I have to pick up a set and thats what Im getting.
Old Jul 28, 2001 | 05:43 AM
berkel's Avatar
Default Re: Whats the best fitting spark plug wires for my 94 gsr? (newgsrdriver)
I would not spend the money on Nology, again. I had them, no diff, except weight reduction from a lighter wallet
I just replaced my Magnecores that were ~2 years old with MSD. I have an MSD ignition and they fit pretty well and are beefy, so should shield well enough.
Generally, don't replace them till their worn out and just go for something with the fit and shielding you want, then consider looks and cost. Manecore and MSD are good but pricey at $70 or so. If I were to do it again, I would prob just get NGK stock...
Take care,
FB
Old Jul 28, 2001 | 06:24 AM
slowerthanu's Avatar
New User
Default Re: Whats the best fitting spark plug wires for my 94 gsr? (berkel)
Stock. I have magnecores and I have had bad luck with them. From what I have heard they are a good company but mine get loose and one of my wires got cut
Old Jul 28, 2001 | 06:53 AM
ARunto's Avatar
Default Re: Whats the best fitting spark plug wires for my 94 gsr? (slowerthanu)
NGK probably the best fitting. Anyone wanna trade me for my MSD ones?
-Alan
Old Jul 28, 2001 | 02:28 PM
LoneWolf's Avatar
New User
Guy who had my `Teg put Neuspeeds on there shortly before I got it. I haven't had any problems.
I'm sure someone makes Neuspeed's wires for them, maybe someone here knows. If you think color coordination is important, they're yellow in color.
Inextricabledrvr
Jun 22, 2009 09:35 AM
RACEPAK
Oct 25, 2004 07:04 AM
Kaneo
Jun 24, 2004 02:03 PM
BoBo Racing
Feb 16, 2003 03:29 PM
KF_S2000
Feb 2, 2002 06:08 PM
