CTR steering wheel on a 5th gen?
yea the CTR one will fit but not the ITR one. no special adapter is needed , just plug and play. i have da s2000 one and it fits on 96+ civics so yea the CTR one will fit but you will not have a horn and no SRS airbag and no cruise control. none of the plugs hook up.
well its kinda hard to tell. i ve done it bunch of times. all i can tellu from experience is that you will have no horn or nothing. the plugs dont plug up. our year accords use the ribbon type cable. and the new civics uses wires. so that means they are incompatible.
on the boltsizes in the middle accords uses a 14mm bolt that holds the steering wheel , same rules apply for preludes and civics.
but 94-00 integras uses a 19mm bolt that hold the steering wheel down to the spline.
only thing i can say is make shure the person you are buying it from. accepts a exchange if it is a integra.
hoped i helped u out.
